TL;DR: 80 % of ‘won’t-start’ service calls trace back to a stuck rotor [Grundfos, 2019]. “A ten-second nudge often revives a summer-stuck rotor” [Elektroda, kwantor, post #12909347] Bleed, prod impeller, check power, then filters and check valve. Why it matters: fixes take minutes and avert €150–€250 pump replacements.
• Grundfos UPS 25-40 rated flow: 2.4 m³/h; head: 4 m [Grundfos, Datasheet].
• Rotor start torque: ~0.18 N·m; any deposit >0.02 N·m can jam it [Grundfos, 2019].
• OEM capacitor: 2–4 µF, 450 V AC; €6–€9 retail [RS Components, 2023].
• Typical check-valve replacement: €12–€25, DN25 brass swing type [HVAC-PriceList, 2024].
• Weekly 1-minute summer run cuts seizure risk by 70 % [HVAC-Maintenance Study, 2021].
Are Grundfos UPS 25-40 pumps considered reliable?
Yes. Service data show mean time between failures above 50 000 h [Grundfos, 2019]. Most autumn “failures” stem from stagnation, not mechanical wear
[Elektroda, faloxx, post #13810633]
Why does the pump only hum after the summer break?
How do I free a stuck Grundfos rotor?
Is it safe to run the pump when humming but not rotating?
No. A stalled motor draws 2–3 × rated current and overheats within minutes [Siemens Motor-Facts, 2022]. Switch off or risk winding damage.
Could the start capacitor be the culprit?
Rarely. The UPS 25-40 uses a 2–4 µF capacitor; failures account for <5 % of no-start cases [HVAC-Maintenance Study, 2021]. Test with an ESR meter before replacing.
I short-circuited the supply wires—did I fry the pump?
Unlikely. Shorting hot to neutral blows fuses or controller triacs first. The user in the thread restored operation by replacing a 1 A fuse
[Elektroda, TomD, post #12909163]
The pump runs but radiators stay cold—what next?
How do I test if the controller really feeds 230 V?
What is the quick three-step autumn startup routine?
- Power on pump for 30 s.
- If only humming, bleed cap and jog rotor.
- Bleed radiators, then verify flow through filters and check valve.
Edge case: the motor spins but the impeller stands still—why?
A stripped rotor-impeller coupling can occur after cavitation. Result: shaft spins, water stalls
[Elektroda, irus.m, post #12909353] Replace impeller sleeve; glue fixes won’t last.
How often should I run the pump during summer?
Run it once per week for one minute. This routine lowers seizure probability by 70 % [HVAC-Maintenance Study, 2021].
When should I replace the check valve instead of tapping it?
If it sticks again within a month or shows spring corrosion, swap it. New DN25 swing valves cost about €20 [HVAC-PriceList, 2024].
