- What is the difference between a 2 pole motor and a 4 pole motor?
Toms96 15906 11
What is the difference between a 2-pole and a 4-pole electric motor?
A 4-pole motor has more pole pairs than a 2-pole motor, so its synchronous rotational speed is lower; the thread gives the formula 60·f/p and the example 50 Hz / 2 pole pairs = 1500 rpm [#16600893] More poles generally give higher torque at lower speed, so you can get low-speed drive without a reducer, but the tradeoff is lower power at the same speed [#16601851][#16601944] The replies also note that higher pole count can increase weight and dimensions and worsen power factor, efficiency, rated current, inertia, and some torque characteristics [#16601944] In practice, the choice depends on the application, and sometimes a fast motor with a gearbox is better than a slow-speed motor without one [#16601944][#16603326]
  • #1 16487662
    Toms96
    I wonder what's the matter with this polarity? Are only 2 and 4 pole motors?
  • #2 16490581
    fuutro
    Help: 1450
    Rate: 837
    Have you heard of pole pairs sometimes marked with the letter p? Maybe about synchronous speed? Induction motors?
    There can be more poles and pairs of poles, but this translates into a greater complication of the structure and its dimensions.
  • #3 16600796
    Toms96
    No, I have not heard of the designation p
  • #4 16600893
    UmyslTechniczny
    Rate: 42
    60 * f / p
    So let's give it 60 * 50/2 = 3000/2 = 1500 rpm
    p-number of pole pairs :)
    -frequency f
    So as you can see the more poles the lower the rotational speed.
  • #5 16601851
  • #6 16601927
    qwert2000
    Help: 10
    Rate: 25
    You won't gain anything at the moment. An ox engine with lower engine speed will have x times less power.
  • #7 16601944
  • #8 16602008
  • #9 16602129
  • #10 16602298
  • #11 16603326
    stasiekb100
    Help: 118
    Rate: 459
    Increasing the number of poles is in favor of the moment and at the expense of power. I'm talking about an example engine that we will rewind to get a different number of pole pairs. From our own observations, a smaller moment is a gentler start at the same power.
  • #12 16603487
The discussion centers on the differences between 2-pole and 4-pole motors, focusing on their operational characteristics such as speed, torque, and efficiency. It is noted that increasing the number of poles results in lower rotational speed but higher torque. The formula for synchronous speed is provided (60 * f / p), illustrating that more poles lead to reduced RPM. The conversation also touches on the implications of motor selection for specific applications, emphasizing that while low-speed motors can provide higher torque, they may not always be the best choice depending on the system requirements. The importance of understanding motor specifications and their impact on performance is highlighted, with examples of practical applications and modifications discussed.
