Locating and Replacing the Fluid Temperature Sensor in Audi A3 8l AGN 1.8
eloziomdoman 21810 1
  • #1 16487686
    eloziomdoman
    Hello, I have an audi a3 8l 99r. 1.8 AGN.
    The problem is that the pointer on the board shows all the time 60 degrees, sometimes it jumps for a moment to 90 ... The thermostat mentioned, after connecting the VAG, the temp is about 90 degrees.
    Are there 2 temp sensors; one gives a reading to the computer, the other on the board?
    If so, where can the temperature sensor be located, which gives a reading on the board.
    Could this be it?
    By the way, I noticed that the tap to drain the coolant is hanging from my cord, it seems to me a temperature sensor. From the beam from which the cable comes out there are two more outlets and are connected to the air inlets. Where should I connect it - I do not see a free place for it.
