Assessing & Replacing Engine Cushions in Renault Laguna 98r, 1, 16V - Car Shakes During Braking
pejot2004 7821 9
How can I tell if the engine mounts in a Renault Laguna 1998 1.6 16V are causing shaking during engine braking, and is replacing the lower mount difficult?
If the engine rocks front to rear, the lower mount/cushion is likely worn and should be replaced [#16487866] The replacement is reported as simple: unscrew 2 bolts, remove the old mount, and install the new one [#16487887]
  • #1 16487804
    pejot2004
    Rate: 14
    The car shakes, especially during engine braking. It seems to me that the cause is damaged engine cushions. For my eye the lower cushion and the upper cushion on the driver's side. How do you rate it? Is replacing the bottom one very troublesome?
    Top cushion:
    Bottom cushion:
  • #2 16487866
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Replace the lower one if you rock the front, rear, engine.
  • #3 16487872
    pejot2004
    Rate: 14
    Does replacing the lower cushion differ from the one shown in the video? The Laguna II is shown here with a different engine. No need to lift the engine, prop it?
  • #4 16487887
    Help: 1405
    Rate: 6430
    You unscrew 2 screws, take out, put in a new one and that's it.
  • #5 16487902
    pejot2004
    Rate: 14
    It's just like the movie. Do you remember what cap? Is a dynamometer key required?
  • #6 16490047
    pejot2004
    Rate: 14
    I have one more question. How many engine mount cushions are there in the car? I know there are two at the top, one is definitely connecting the gearbox to the engine (the one in the video). Is there one more underneath the car that I don't know about?
    Link https://obrazki.elektroda.pl/1_1237931037.jpg
  • #7 16505006
    pejot2004
    Rate: 14
    I started to replace the pillow. As always, bad luck does not leave me. The bolt - this one more from the rear of the car twists, it can't be unscrewed. What now?
  • #8 17939394
    Aaaabbbbbcccccc
    And how did you deal with that pillow? I have the same problem, the bolt closer to the cabin has loosened and cannot be unscrewed or screwed, it turns loosely.
    Is there any key approach?
    I guess the nut should be welded?
  • #9 17939417
    pejot2004
    Rate: 14
    The car went to the mechanic then and he replaced the pillow.
  • #10 17939500
    Aaaabbbbbcccccc
    Thank you for your answer.
The discussion revolves around the issue of engine shaking during braking in a Renault Laguna 98r, attributed to potentially damaged engine cushions. Users suggest replacing the lower engine cushion, noting that the process involves unscrewing two screws to remove the old cushion and install a new one. There are inquiries about the differences in replacement procedures compared to other models, specifically the Laguna II, and whether engine lifting is necessary. Some users encounter difficulties with stubborn bolts during the replacement process, leading to suggestions of professional assistance. The conversation highlights the number of engine mounts in the vehicle and the challenges faced during DIY repairs.
