Air in Brake System: Renault Laguna II Rear Wheel Brake Hose Replacement & Fluid Issues
robson871101 7971 9
  • #1 16386183
    robson871101
    Hello, today I changed the rear right wheel brake hose in lagoon II before I replaced all the liquid from the tank, then I poured it and the liquid stopped reaching the rear wheels, the two of us vented the system and nothing was flying to the rear wheels, so dad fired the car and pumped and after a while the pedal fell and the stop and abs lit and the pedal all the time falls to the floor, although the tank is full and the fluid is barely flowing from the front wheels and the rear wheels are not even a drop. Please help how to fix it? I will add that the car is on four blocks, i.e. in the air [/ movie]
  • #2 16386193
    olekt2002
    Tow truck and to the mechanic. Unfortunately, after such a description of attempts to repair the fault - only a mechanic.
  • #3 16386198
    robson871101
    I suppose something can be done about it?
  • #4 16386199
    olekt2002
    robson871101 wrote:
    I think something can be done about it?
    And why not ???
  • #5 16386212
    robson871101
    and how to avoid the mechanics because the car needs tomorrow
  • #6 16386227
    olekt2002
    You know ... the brakes are a matter of life - yours or other innocent ...... Decide.
  • #7 16386231
    robson871101
    Anyone else have an idea how to bleed it?
    yezz
    Bleed the brake pump through the wires and the ABS pump on the engine on, first it starts to bleed from the farthest wheel, i.e. the left rear wheel.
  • #9 16386276
    olekt2002
  • #10 16387572
    robson871101
    It worked without a mechanic, my colleague "olekt2002" with the advice of my colleague "yezz", I did the entire vented system step by step as he ordered to do and everything works ABS is not lit STOP also does not light everything is ok :) I close the topic :)
The discussion revolves around issues encountered after replacing the rear right wheel brake hose on a Renault Laguna II. The user reported that after the replacement and fluid refill, brake fluid was not reaching the rear wheels, leading to a soft brake pedal and illuminated ABS and STOP lights. Responses suggested that the brake system needed proper bleeding, specifically starting from the farthest wheel. A successful method was shared, which involved bleeding the brake pump and ABS pump while the engine was running. Ultimately, the user confirmed that following the step-by-step guidance resolved the issue without needing a mechanic.
Summary generated by the language model.
