VW Golf 5: Front Door Open Sensor Location & Yellow ESP Indicator Meaning, On/Off Guide
Kretywy 4794 8
  • #1 16492970
    Kretywy
    I have a problem with the front door open sensor. The light on the board is lit despite the closed flap. Where is such a sensor located?
    Second problem. The (yellow) ESP indicator is also on the board - how do I turn it off, does it mean that ESP is turned off?
    best regards
    andrzej20001
    Help: 1578
    Rate: 6669
    You have a thin sensor in the lock (2 wires). As for esp is vag diagnostics. Unless you have disconnected the battery, you need to drive the car, fire it up and it will go out.
  • #3 16493017
    Kretywy
    The car was a crash. If that sensor was there, it's gone. What to do to make the computer sense that the hatch is closed (without the sensor) because the wipers do not work when I am parked.
  • #4 16493050
    andrzej20001
    Help: 1578
    Rate: 6669
    Short the wires and it should be approx.
  • #5 16493057
    Kretywy
    YES, but where can I find these cables? Because the entire front was overhauled. Where I find them closest to the boards.
    milejow
    Help: 1563
    Rate: 5148
    Reverse-shorted cables are open mask.
    In the area of the bonnet lock.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 16494476
    Kretywy
    When replacing the bumper, I didn't notice any cables in the lock. But I'm looking for nothing
    The second thing. The AIR BAG indicator is on. No wonder, I don't have a passenger airbag. And the question is, how do I connect a new pillow, everything will work after resetting the error?
    How much is such a reset in the workshop?
  • #8 16494591
    adam7009
    Help: 656
    Rate: 1635
    You didn't notice, because the cables from the engine compartment side are.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #9 16494840
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Since the car after the accident and fired up the airbag, resetting the errors will not help because there is a record about the accident and you need to have the driver cleaned or replaced.
The discussion revolves around issues with a VW Golf 5, specifically the front door open sensor and the yellow ESP indicator. The front door open sensor, located in the lock mechanism, may not function properly if damaged, especially after a crash. Users suggest shorting the sensor wires to simulate a closed state. The yellow ESP indicator can typically be reset by driving the vehicle, but if the airbag light is also on due to missing components, a reset may not suffice without addressing the underlying issues. The conversation highlights the need for proper wiring checks and potential repairs following an accident.
