2004 VW Golf V: Right Door Remains Open Despite Central Locking Activation
mireczek666 106647 17
Why does the right door on my 2004 VW Golf click twice when I lock it but still stay open, and how can I fix it?
The most likely cause is a broken wire in the door harness, especially in the rubber boot between the door and the body; in this thread, repairing those broken wires solved the problem [#11612160] Before that, others suggested checking or replacing the door lock/actuator and its microswitches, since the lock should close with two strokes and can fail internally [#11501242][#11502326][#11506613] It was also advised to inspect the harness connections and scan comfort module 46 for faults, because bad contacts there can stop the lock signal from reaching the door [#11541027][#11545544]
  • #1 11501162
    mireczek666
    Rate: 43
    Hello, I have a 2004 V golf.
    On the right side, the door does not close for me, when I press the close, I hear 2 clicks in this door, and the door remains open. I would like to add that the door cannot be opened from the inside (child lock is off).
  • #2 11501242
    decybel91
    Help: 1021
    Rate: 4207
    Replace the lock.
  • #3 11501425
    mireczek666
    Rate: 43
    It seems to me that it is something with an electrician, because it is audible as if it closed twice. How can I check the lock after disassembling the lock?
  • #4 11502326
    CAMARENA
    Help: 53
    Rate: 110
    It should close with 'two strokes'. Most likely, the switches in the castle to be replaced.
  • #5 11506613
    benyy1
    Help: 15
    Rate: 133
    Unscrew the lock, improve February in the actuator, check the micro-switches and the harness on the post.
  • #6 11522578
    mireczek666
    Rate: 43
    I bought a drug, changed it, and when I closed it to check if it worked, I still didn't open it. Learning for the future to buy new locks
    How do I open it? the plastics are removed.
  • #7 11522944
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4169
    mireczek666 wrote:
    I bought a stimulant, changed it, and when I closed it to check if it worked, I still didn't open it.
    Because the locks do not work after closing the door, but after closing the bolt with a screwdriver. The wires come out of the lock - drive to an electrician from the vag group, then you should open it with a small combination.
  • #8 11540034
    mireczek666
    Rate: 43
    I opened the door by giving a plus in the marked place, in my opinion the voltage is too low. Where can I find cubes that may need to be cleaned?
  • #9 11540299
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4169
    And the lock has the same number and index? There are big differences on the inside, even though they are identical on the outside.
  • #10 11541027
    masterofhardcore
    Rate: 25
    And take the car to the computer and see the comfort module if there is no error. If there are bad contacts somewhere, it will turn out that the signal is impossible.
  • #11 11543202
    mireczek666
    Rate: 43
    Vag has no option to connect to the door. The lock is original, the lock symbol is as in the previous one.
    Where can I find some cubes, starting with the right door?
  • #12 11544155
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4169
    mireczek666 wrote:
    vag has no option to connect to doors.
    But it has the option to connect to module 46.
  • #13 11545544
    masterofhardcore
    Rate: 25
    As the previous speaker wrote. Module 46 is a comfort module that is connected to the original central locking and electric windows. This is your door. If you have any mistake, you will know where and what to look for.
    As for the cubes, there are door harness cubes in the door, on the pillar at the bottom hinge under the upholstery and behind the relay board.
  • #14 11545611
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4169
    And when there are cranks in the door, we choose 35.
  • #15 11545801
    masterofhardcore
    Rate: 25
    Well, that's right. A colleague did not write what equipment he has.
  • #16 11612160
    mireczek666
    Rate: 43
    Problem solved - broken wires in the rubber reaching the door.
  • #17 18989911
    Stiwen1
    Rate: 288
    Hello, I will dig up the topic, I have a problem, but not with the golf, only the Skoda Octavia II with the remote control will close and the rear door will open with the key, also only the rear front door from the driver will mechanically close with a key, the windows work flawlessly, there are 2 pieces of electric windows, the light turns on after opening every door. Only the front doors on the left and right do not close and do not open, cables in the grommets ok, in comfort no errors I changed the comfort modol the same button in the driver's door works the same as the remote control, I do not know what someone can look for, with my friends any idea.
  • #18 19077311
    krzysztof6711
    Rate: 10
    Hello, it's cold February in the cables under the feet of the driver and the post - re-solder the cables connecting together for 2-3 pieces, although they will be insulated isolate, I did it 2 times
✨ The discussion revolves around a malfunctioning right door on a 2004 VW Golf V, which fails to close despite central locking activation. Users suggest various troubleshooting steps, including replacing the lock, checking the micro-switches, and inspecting the wiring harness for damage. One user identified broken wires in the rubber grommet as the root cause of the issue. Additional advice includes examining the comfort module for errors and ensuring proper electrical connections. The conversation also touches on similar issues with a Skoda Octavia II, indicating common electrical problems across these models.
