VW Golf 5: ESP, Tire Pressure & Power Steering Controls After Battery Replacement
OzonexUs98 67110 1
  • #1 18820129
    OzonexUs98
    Level 4  
    Hello, after replacing the battery in the Volkswagen Golf 5, the ESP and tire pressure controls (probably the power steering, the one in the photo) are lit. My question is, is it possible to somehow remove them yourself or do they need to be removed by the computer because while the tire pressure will not be a problem, I do not know how to deal with the other two. Thank you in advance for your help :) VW Golf 5: ESP, Tire Pressure & Power Steering Controls After Battery Replacement
  • #2 18820152
    danielzy
    Help: 167
    Rate: 319
    Nothing needs to be done, after driving a few hundred meters they should go out by themselves.
