Kitchen Chandelier Flashing and Blown Fuses: Possible Damage to Entire Lighting System?
luzmc 5595 4
  • #1 16494185
    luzmc
    I have two electrical installations in the apartment - one for sockets, the other for lighting. Today I noticed that the bulb in the kitchen chandelier begins to flash. I thought the light bulb burned out and when I tried to unscrew it, something flashed, shot in the chandelier and blown fuses in the apartment. After turning on the fuses, I only have the light in the hall in the chandelier next to the box. In all other rooms, the lighting stopped working. I guess you have to call an electrician, but I have a few questions.
    1. What could happen if the entire lighting system was damaged or simply broken in one place and the electrician should easily locate and fix it?
    2. Can I use the working chandelier freely in the hallway, and can the switches in rooms where there is no light stay in the on position, or is there a risk of short circuit? (in each case there is a different set of on and off positions, and unfortunately I do not remember in which room the light was on at the time of the short circuit and in which not, therefore any switch may remain in the on position).
    qadam12
    Help: 62
    Rate: 254
    You have one installation and several circuits.
    Added after 53 [seconds]:
    luzmc wrote:
    should an electrician easily locate and fix it?
    Yes
    Added after 38 [seconds]:
    luzmc wrote:
    whether the entire lighting installation has been damaged
    no
    Added after 45 [seconds]:
    luzmc wrote:
    Can I use the operating chandelier freely in the hall, and can the switches in rooms where there is no light can remain in the on position
    Yes
    kozi966
    Help: 599
    Rate: 1285
    Have you checked the staircase protection (if the installation has three phases)?
  • #4 16494268
    luzmc
    Yes, in the staircase the fuse was blown into my apartment, after turning it on the situation is as described above.
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4286
    Well, you can't do without an electrician. Somewhere the cable burned, and there is no fault through the forum.
