Televes V ZENIT directional antenna Do you need an amplifier / power supply?
Rafii[H] 5745 9
Does the Televes V ZENIT directional antenna with LTE filter come with a built-in amplifier or power supply, or do I need to buy one for reception about 56 km from the transmitter?
No, this antenna does not come as a powered amplified set; it has a built-in balun, and at about 56 km you should try it passively first before buying any amplifier [#16495943][#16497681] The thread warns that adding an amplifier in advance makes little sense and that a strong amplifier can distort the DVB-T signal, so if reception is still unsatisfactory, use only a low-power amplifier [#16497681][#16500838] It is also noted that Chrzelice does not transmit MUX8, so if you need that multiplex you will likely need a separate antenna or a different direction rather than relying on one combo antenna [#16497681][#16500838] For the Pludry area, one reply suggests checking MUX1/2/3 from Chrzelice and Klepaczki, while MUX8 should be tested from Góra Św. Anna or Węczyca because polarization and SFN issues may matter [#16502445] Before testing, clear the receiver channel list and scan manually [#16502445]
  • #1 16495885
    Rafii[H]
    Help: 6
    Rate: 85
    I'm planning to buy a Televes V ZENIT directional antenna with LTE filter (149201) and I have a question, does this antenna already have an amplifier / power supply in the set? Do you have to buy one?
    Transmitter: Opole "Chrzelice"
    Distance from the transmitter: ~ 56km
    Thank you in advance for your help
  • #2 16495943
    sosarek
    Help: 9318
    Rate: 15512
    The antenna has a built-in balun, an amplifier should be unnecessary at this distance.
    Why don't you think about buying an antenna that will also receive MUX8?
    Z
    Pka, Poznań, 60-850
  • #3 16495968
    Rafii[H]
    Help: 6
    Rate: 85
    Well, MUX-8 would also be useful. Any suggestion? I always thought that antennas without an amplifier in my area received poorly.
  • #4 16495970
    Rafii[H]
    Help: 6
    Rate: 85
    I need help in selecting equipment for TV installation for DVB-T reception.
    The installation should look more or less like in the picture:
    One antenna on the roof, a splitter in the attic for both rooms, each room will have a TV set and two radios.
    Please help me choose a combo antenna, splitters, antenna amplifier / power supply.
    Distance from the transmitter: ~ 60km
    Added after 16 [hours] 16 [minutes]:
    Nobody can help?
  • #5 16497681
    M.Mikolajski
    Help: 13
    Rate: 22
    The basic UHF 1-2-3 mux 8 muxs are transmitted from the Chrzelice transmitter, the mux 8 does not appear as a program from this transmitter, so the combo antenna will not be needed, only a separate one for another direction and a crossover - the antenna you mentioned is a high-quality brand product and supply its amplifier in advance without checking the quality of the received signal passively misses the point - there is a strange rumor in the nation that you need to add amplifiers to the antennas and the stronger the better - nothing more wrong - ALWAYS set the antenna passively and in the position of the best reception when it is not satisfactory we attach a low-power amplifier to the installation, because a strong amplifier will certainly distort the signal
  • #6 16497702
    Rafii[H]
    Help: 6
    Rate: 85
    MUX-8 only from the transmitter on Mount St. Anna. Combo could handle it? are these transmitters too far apart?
  • #7 16498863
    M.Mikolajski
    Help: 13
    Rate: 22
    Dear colleague, you can not answer this question because you did not provide your own location, so it is not possible to judge whether these two directions coincide with the place where you want to receive these muxs - the principle of functioning on the forum is to provide data on your location, environmental conditions, etc. necessary data - rather, you qualify for a warning for breaking the forum rules
  • #8 16500838
    irekr
    Help: 1192
    Rate: 1238
    I will add this to the topic of "amplifiers in the nation": to receive DVB-T you need a signal 10 times weaker, if you give the receiver input over 2 mV, expect trouble. And in fact, for the analog at this level, good reception started.
    Chrzelice is not equipped with a MUX8 transmitter - and I don't think they will - but note that from Góra Św. Anna, it is broadcast on channel 6, which is the same as from Koszty, Ślęza, Śnieżne Kotłów, Czarna Góra, Sucha Góra and Solina. Differences in polarization are definitely not enough, especially in Lower Silesia. Personally, I think this network configuration is wrong.
    Many of my friends living in Lower Silesia signal to me that they have a lot of trouble with MUX8, for example in Brzeg or Prudnik. The northern part of the Opolskie Voivodeship has a very good reception from Kobyla Góra near Ostrzeszów, this signal is stable even in Opole.
    And the lack of information about the location (it does not have to be an exact address, a town or a nearby intersection in a larger town is enough) as a "delicate attention" of the moderator.
    Do not take the information on the dvb-t map pages for granted, this data is only indicative and should rather be considered as a "wish list". Anyway, like all computer simulations.
    And do not give us a list of broadcasting facilities, many in this forum know these facilities from the foundations to the ends of the masts, some even sat on their tops.
    PS. I don't see much point in a combo antenna.
  • #9 16502366
    Rafii[H]
    Help: 6
    Rate: 85
    My location is the town of Pludry in the Opole region.
  • #10 16502445
    irekr
    Help: 1192
    Rate: 1238
    .... And that changes things.
    Of course, there will be no tests, but MUX1 / 2/3 has to be checked from Chrzelice and Klepaczki (Węczyca Wielka near Częstochowa).
    MUX8: both directions must be checked, theoretically Góra Św. Anna is closer, but SFN on this channel can cause a lot of problems (mainly signal from Ślęza, received to Częstochowa).
    Z Węczyca - sheet 9 in VERTICAL polarization which requires a rather separate antenna. The advantage of Węczyca is that there is no other DVB-T transmitter nearby on this channel and the signal is of relatively better quality. The strength is very similar for Węczyca and G. Św. Anna
    MUX8 is from Góra Św. Anna in horizontal polarization, you have to remember about it when doing antenna tests.
    And most importantly: before each check, clear the list of channels in the receiver and set the scan to manual mode only. All vending machines in these conditions can confuse us quite a lot.
✨ The discussion revolves around the Televes V ZENIT directional antenna (model 149201) and whether an amplifier or power supply is necessary for optimal performance at a distance of approximately 56-60 km from the Opole "Chrzelice" transmitter. Responses indicate that the antenna has a built-in balun, making an external amplifier generally unnecessary at this distance. However, concerns about receiving MUX-8, which is transmitted from a different location (Góra Św. Anna), lead to suggestions for a combo antenna or separate antennas for different directions. Participants emphasize the importance of passive antenna setup and caution against using strong amplifiers that may distort signals. The need for proper location data for accurate advice is also highlighted.
