Checking Stability of Wired Internet Connection: Identify Provider or Personal Issues
radifumi 25407 8
  • #1 16501182
    radifumi
    Rate: 28
    How to check the stability of the Internet connection - once the Internet is good and once it is poorly open, I would like to know if it is the fault of the provider or mine. I have a wired connection (without a router).
  • #2 16501246
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    You call CMD.
    then, for example:
    ping wp.pl -t
    Aborting the Ctrl-C test
  • #4 16501320
    radifumi
    Rate: 28
    wpisuje ping gogle.pl wynik reply from 172.217.18.3 bytes=32 times=32ms ttl=56
    172.217.18.3 bytes=32 times=38ms ttl=56
    172.217.18.3 bytes=32 times=42ms ttl=56
    aproximate round trip.... min=32ms max=42ms average= 36ms
    na adres ping wp.pl average 17ms
  • #6 16501455
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    radifumi wrote:
    enter ping gogle.pl result reply from 172.217.18.3 bytes = 32 times = 32ms ttl = 56
    172.217.18.3 bytes = 32 times = 38ms ttl = 56
    172.217.18.3 bytes = 32 times = 42ms ttl = 56
    aproximate round trip .... min = 32ms max = 42ms average = 36ms
    to ping wp.pl average 17ms
    And where the attribute: "- t". to the command: "ping" and the correct page address.
    This is what it should look like:
  • #7 16502636
    radifumi
    Rate: 28
    Microsoft Windows [Version 6.3.9600]
    (c) 2013 Microsoft Corporation. Wszelkie prawa zastrzeżone.
    C:\Windows\System32>ping gogle.com -t
    Pinging gogle.com [216.58.207.68] with 32 bytes of data:
    Reply from 216.58.207.68: bytes=32 time=31ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=33ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=32ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=34ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=46ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=49ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=38ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=871ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=36ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=42ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=47ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=37ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=43ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=63ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=40ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=39ms TTL=56
    Reply from 216.58.207.68: bytes=32 time=45ms TTL=56
    Ping statistics for 216.58.207.68:
    Packets: Sent = 27, Received = 27, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 31ms, Maximum = 871ms, Average = 68ms
    Control-C
    ^C
    Dostawca internetu powiedział że z ich strony jest wszystko ok,być może spowalnia coś program antywirusowy,jakiś program inny,brak aktualizacjii windows 8 itp.
  • #8 16502777
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    See what ping I have, your ping is very unstable,
    I have a ping with Ruter.
    It depends on who is the supplier and distance.
    Although you do not have any losses because then it sneaks at all.
  • #9 16503510
    radifumi
    Rate: 28
    a private company provider after orange links, i.e. it is not a fault on my part?
To check the stability of a wired internet connection, users can utilize the command line tool "ping" to monitor response times to various websites, such as "gogle.pl" or "wp.pl". Continuous ping tests can be executed using the command "ping [website] -t", which provides real-time feedback on latency and packet loss. Additionally, software tools like PingPlotter and Axence NetTools can be employed for more detailed analysis over time. Users should consider factors such as their internet service provider and physical distance from the service point, as these can affect connection stability. If ping results show significant fluctuations, it may indicate issues with the provider rather than local hardware.
