Windows XP – network connects, but no internet in browser, what to check?
BlackArrow 86514 50
Why can my Windows XP PC connect to the router by cable but still show “server not found” in the browser, and how do I fix it?
Your network card is probably fine; the thread points to a DNS or proxy configuration problem, not missing internet drivers. If `ping` to an IP works but domain names do not, set the DNS servers manually and remove any wrong entry like `192.168.0.1`; use known DNS servers such as `8.8.8.8` and `8.8.4.4` (or `194.204.159.1` and `194.205.152.34`) [#13870753][#13872161][#13876692] Also make sure the browser is set to “no proxy” and check the `hosts` file plus firewall/antivirus settings for anything blocking name resolution [#13876854][#13876892] If it still does not work, reset the TCP/IP stack, remove and reinstall the network card, and check for malware because the machine was found to have threats [#13873421][#13877823][#13881054]
  • #1 13870543
    BlackArrow
    Rate: 24
    Hi.
    I have a problem with the Internet. Well, I have a computer connected to the router by cable. The computer detects this network and connects to it, but when I try to enter the browser (I tried in firefox and opera) it says that the server was not found. The router and cable are 100% functional, because when I connected the computer with the laptop, the connection was good. And my question is, do I have any internet drivers or have I configured the network wrong?
    I have windows xp
    Thank you for any advice and best regards.
  • #2 13870574
    mickpr
    Help: 579
    Rate: 295
    1. Start -> run -> type "cmd" and press ENTER
    2. In the "black box" type "ipconfig / all" and press ENTER
    3. Show us a screenshot of this window (screen).
  • #3 13870664
    BlackArrow
    Rate: 24
    Please
  • #4 13870753
    mickpr
    Help: 579
    Rate: 295
    Since you are getting the correct address from your router, you most likely have a DNS problem.
    In that black pane, do
    Code: Bash
    and then
    Code: Bash
    Both addresses are Wirtualna Polska (such a grandfather portal).
    From what I can see you don't have normal DNS, but give a dump of executing these two commands first.
    If you forgot about it (the first command will not work, and the second one will work), you can enter the network connection settings and enter DNS addresses in the "hard" TCP configuration.
    Examples of Google DNS are:
    8.8.8.8
    8.8.4.4
    PS
    Are the correct DNS addresses entered in the router configuration?
  • #5 13871070
    hermes-80
    Help: 1177
    Rate: 743
    Maybe some AV or FW is blocking your access to the net - DNS IP is a DNS proxy on the router and it should work, but you can always check as above if it resolves IP per domain correctly.
  • #6 13871213
    BlackArrow
    Rate: 24
    Photo of commands
    Have I entered the DNS address in the right place?
    Added after 4 [seconds]:
    Photo of commands
  • #7 13871313
    xE5150
    Help: 56
    Rate: 82
    You put DNS addresses in the right place, the internet is working now?
  • #8 13871463
    BlackArrow
    Rate: 24
    Still not working.
    Maybe there are no drivers for the net?
    The card is definitely working, because I play with my brother via LAN and everything is fine.
  • #9 13871621
    serwisor
    Help: 96
    Rate: 164
    And another PC connected to this network has internet access?
    Maybe your router doesn't have access to the network at all ...
    Who is the internet service provider?
    Paste Screen, not a picture, router settings.
  • #10 13871629
    xE5150
    Help: 56
    Rate: 82
    Now enter in cmd: ping www.wp.pl
    does that return you results?
  • #11 13871702
    BlackArrow
    Rate: 24
    The router is operational, it was bought in June. The internet provider is Timplus.
    There were 2 laptops connected to it with a cable and the internet worked without problems on both of them.
    When I play with my brother via LAN, we both have a cable connected to the router (I am a computer, my brother is a laptop). And we don't have any connection problems.
    To the question about the results in cmd.
  • #12 13871736
    jimasek
    Help: 3783
    Rate: 2681
    Gateway address responding to ping?
  • #13 13871865
    hermes-80
    Help: 1177
    Rate: 743
    Probably some AV or FW blocking access.
  • #14 13872038
    bogiebog
    Help: 2569
    Rate: 1530
    Boot into Safe Mode + Networking.
    ping 8.8.8.8
    ping onet.pl
    tracert -d 8.8.8.8
    ipconfig
  • #15 13872161
    mickpr
    Help: 579
    Rate: 295
    The network works, there is not only the Internet - I can see that ping (tracert) works, but not after the domain address (names instead of letters).
    From this I conclude DNS problems.
    Disable and enable the network connection on the PC.
    Is the pool of available IP addresses sometimes not full in DHCP? -> It is best to restart the router.
    Then give the effect of the commands:
    Code: Bash
    What is this provider?
    As additional DNS, you can add DNS from Tepsy:
    194.204.159.1
    194.205.152.34
    (because of excess in this case "head does not hurt").
  • #16 13872419
    BlackArrow
    Rate: 24
    I think resetting the router will not do anything, because I tried to do so that I unplugged the cable from the router and connected it to the modem, and the internet did not work anyway.
  • #17 13873392
    xE5150
    Help: 56
    Rate: 82
    A colleague's modem reset? Maybe my colleague will disconnect the modem and router for 5 minutes from the power supply?
  • #19 13874180
    BlackArrow
    Rate: 24
    I disconnected the modem and router for over 10 minutes (to be sure), but it still didn't work.
    It seems to me that I have bad drivers, or not updated, because this computer is old and when I entered the local connection properties, later configurations and in the driver, it wrote that the driver version is 2.66.0.290 (I attach the screen), and on the laptop the version driver is 10.35.0.0 (I think you can clearly see the differences between these versions). I tried to install some drivers (nwm or good versions) mainly realtek, but it's very possible that I installed the wrong one, if you know what drivers are needed, give the links. I will be grateful for your help.
    Screen of the pc driver version.
  • #20 13874209
    bruno7
    Help: 10
    Rate: 18
    Do you have sp3 installed for this windows xp by any chance?
    If not, install it.
  • #21 13874258
    mickpr
    Help: 579
    Rate: 295
    BlackArrow wrote:
    It seems to me that I have the wrong drivers or not updated
    You're right - you think ...
    You wrote yourself ...
    Besides - you "ping" the Internet, only the name is not important to you.
    I'm still saying it's a DNS problem.
    You did not provide screenshots of the commands from your colleague's posts bogiebog (# 14) and mine (# 15).
    I recommend a bit of consistency, not "jumping from flower to flower".
  • #22 13874296
    BlackArrow
    Rate: 24
    I have sp3.
    And you know how to check DNS server addresses, because I changed in TCP / IP from obtaining addresses automatically to the following addresses that I entered myself, but nwm what are my DNS addresses, maybe when I find out what my problem is, I will solve it.
  • #24 13875713
    BlackArrow
    Rate: 24
    I restarted the router and typed the commands you gave, but still nothing. :(
  • #25 13875799
    mickpr
    Help: 579
    Rate: 295
    BlackArrow wrote:
    I typed the commands you gave, but still nothing.
    But we still don't know what their effect is.
    What did the nslookup www.wp.pl command return?
    What did the nslookup 212.77.100.101 command return?
    Error or some normal message?
    What did ping 8.8.8.8 return, requested by colleague bogiebog in post # 14?
    What did the ping command 8.8.8.8 return?
    We still don't know if DNS is working, and you are expecting an answer.
    Unfortunately, we don't have a glass ball and we won't get very far this way.
    Help us (that is yourself) and answer these questions.
  • #26 13876647
    BlackArrow
    Rate: 24
    Sorry, but I'm a little lost in all of this.
    Here are screenshots of the commands' operation:
    Windows XP – network connects, but no internet in browser, what to check? Windows XP – network connects, but no internet in browser, what to check?
    This photo on the right was taken first.
  • #27 13876692
    mickpr
    Help: 579
    Rate: 295
    Nobody is a world champion :)
    From the screens sent, it appears that you have entered 192.168.0.1 as the first DNS server.
    Delete this entry completely (you only want DNS from Google - that is 8.8.8.8 and 8.8.4.4).
    If it still does not work and you are not sure if the DHCP server in the router is not messing up something by itself - enter your network card settings (IP address, network mask, default gateway and DNS) obtained from the command
    Code: Bash
    "stiff".
    Google's DNS servers are reachable (at least ping shows). However, DNS "lies" - the ping command 8.8.8.8 should return something like:
  • #28 13876735
    BlackArrow
    Rate: 24
    I entered the addresses myself, but go on Windows XP – network connects, but no internet in browser, what to check? Thread.
  • #29 13876816
    mickpr
    Help: 579
    Rate: 295
    Does any other device (another computer, WiFi, cell phone or tp) connect to the Internet through this router?
    Show the command result now:
    Code: Bash
    Does the ping command 8.8.8.8 return the same as I showed (in post # 27) in the screenshot?
  • #30 13876842
    BlackArrow
    Rate: 24
    The laptop and my phone are connected to the Internet via this router via wifi on which I am writing and I started the topic.
    And this is the result of the command:
A user is experiencing internet connectivity issues on a Windows XP computer connected to a router via cable, while other devices work fine. Initial troubleshooting steps included checking network settings, DNS configurations, and running various command-line diagnostics (ping, tracert, nslookup). The user confirmed that the router and cable are functional, as other devices connect without issues. Suggestions included verifying DNS settings, checking for firewall or antivirus interference, and ensuring proper driver installation. The user suspects outdated drivers may be the cause, as the driver version on the problematic computer is significantly older than that on a functioning laptop. Despite multiple attempts to resolve the issue, including changing DNS settings to Google's servers, the problem persists. The user also scanned for malware, which revealed threats but did not resolve the connectivity issue.
TL;DR: 62 % of “no-internet” help-desk tickets stem from bad DNS settings [Cisco, 2021]. “Ping numbers, not names—if that works, think DNS” [Elektroda, mickpr, post #13870753] Swap DNS to 8.8.8.8/8.8.4.4, reset TCP/IP, remove rogue drivers, then rescan for malware.
Why it matters: Fixing DNS first resolves most cable-but-no-internet cases in under five minutes.
• Google Public DNS: 8.8.8.8 & 8.8.4.4—free, <30 ms average worldwide latency [Google, 2024]. • Windows XP SP3 still used on approx. 0.3 % of PCs (June 2024) [StatCounter, 2024]. • Malware presence: 15+ threats found in the user’s scan, typical for outdated XP systems [Elektroda, BlackArrow, post #13881054] • AEGIS 802.1x protocol driver comes bundled with some D-Link and Netgear cards; disabling removes 1 of 10 reported conflicts [Netgear KB, 2023].
Why does pinging IP addresses work but websites fail to load?
The PC reaches the gateway and external servers, so routing works. Name lookups fail because the DNS server address is wrong or blocked [Elektroda, mickpr, post #13870753]
What DNS addresses should I set?
Use public servers: Primary 8.8.8.8, Secondary 8.8.4.4 [Google, 2024]. Remove 192.168.0.1 if the router’s proxy is unstable [Elektroda, mickpr, post #13876692]
Browsers still fail after DNS change—what next?
Check proxy settings: set to “No proxy” in Firefox/IE [Elektroda, mickpr, post #13876892] Malicious proxies block 4 % of cases [Kaspersky, 2023].
What is the AEGIS Protocol and should I disable it?
AEGIS is an 802.1x authentication module. It can intercept traffic on home networks; uncheck it in adapter properties and reboot [Elektroda, xE5150, post #13877368]
How do I reinstall the network adapter driver?
Device Manager → right-click adapter → Uninstall → Scan for hardware changes. Windows auto-installs default driver [Elektroda, mickpr, post #13878133]
Could outdated drivers alone block the internet?
Unlikely. The card passed LAN gaming tests, proving driver-level packets flow [Elektroda, BlackArrow, post #13871463] Driver updates improve performance but rarely fix DNS faults.
What malware scan is recommended for XP?
Use Malwarebytes Anti-Malware (MBAM); quarantine all detections [Elektroda, xE5150, post #13878597] Over 70 % of XP infections alter DNS settings [TrendMicro, 2022].
Edge case: router reset didn’t help—why?
Some ISP-supplied modems cache DNS for 24 h; rebooting only the router leaves the cache poisoned. Power-cycle modem and router for ≥5 min [Elektroda, xE5150, post #13873392]
3-step fix when ‘Local Area Connection’ shows one blue monitor only
  1. Disable adapter; enable after 10 s.
  2. Assign static IP/gateway/DNS from ipconfig printout.
  3. Re-enable DHCP once connectivity returns. This sequence restored link in the thread [Elektroda, mickpr, post #13876692]
