Opel Corsa B On-Board Computer Display Issue: Not Showing Radio Station Frequency
makaronmc 7605 3
  • #1 16501218
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    Hello gentlemen...
    I have a problem with my "on-board computer" which shows the time, date and temperature .. when turning on the radio it should show the station frequency ...: /
    In general, the display is very good ... the date and time are often reset, sometimes nothing is displayed, it was helped by tapping: /
    After turning the ignition switch ... the time, date and temperature are displayed:
    The radio looks like this, from what I associate it, it is factory:
    After turning on the radio .. frequency should appear in place of the date ..
    I do not know if something is not connected ... or if the display itself can be replaced: /
  • #2 16501459
    bubu1769
    Help: 1177
    Rate: 2374
    In these displays, cold February is quite common at the connector, it is worth taking it apart and checking it.
  • #3 16502290
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    This morning .. even for a moment the frequencies appeared hehe :)
  • #4 16503051
    bubu1769
    Help: 1177
    Rate: 2374
    Check the connector.
