Mercedes Actros 4141 EPS Gearbox Error GS32 - High Outside Temperature Impact
Janek2007 34383 14
Why does a Mercedes Actros 4141 EPS gearbox show a red GS32 gearshift failure when it gets hot and then work again after cooling down?
GS32 points to an input error of the intermediate shaft speed sensor, so the main things to check are that sensor, its mounting, and the wiring/connectors at the EPS/gearbox [#16506301] [#16524501] [#16531635] Several replies say the sensor is screwed on the left side of the gearbox and that you should verify its installation and measure the sensor resistance at the controller connector [#16524501] [#16531635] Because the fault appears mainly when the vehicle is hot, inspect all plugs and cables for poor contact, chafing, wet/oxidized copper, and treat the connectors with contact spray [#16515037] One reply also recommends checking the wiring with a test lamp, not only with a meter, because a weak wire can still look good on continuity but fail under load [#16527334] If the code stays even with a replacement EPS driver, the problem is likely on the sensor/installation side rather than the module itself [#16516578]
  • #1 16506274
    Janek2007
    Rate: 16
    Hello, I have a problem with Mercedes actros 4141 EPS gearbox at high outside temperatures while driving is displayed in red GS gearshift failure after switching off the ignition and it was impossible to change the gear the driver stopped, powers the engine, the figure started 2 minutes and it was ok after 2 hours of driving a similar situation but did not stop the engine and only stopped the small teaching passed the large did not appear GS32. The next day it was ok I run but the word GS was displayed in red and after stopping 3 hours large teaching passed but the outside temperature was definitely smaller. Do you have any idea for this failure, I will add that in Bs msm error Bs 0 4047
  • #3 16506336
    Janek2007
    Rate: 16
    Thanks buddy we will try to repair it but I still have a question since GS is burning red and gears are falling, something in the module is not happening
  • #4 16506355
    Foxtrott
    Help: 253
    Rate: 944
    I suggest you go to a computer diagnosis then you will have practically everything "on the tray" and so it is a divination of coffee grounds what could happen.
  • #5 16506356
    Janek2007
    Rate: 16
    Ok, I'll let you know what happened
  • #6 16515027
    Janek2007
    Rate: 16
    Hello, buddy, the problem is back, it got warm, my gears disappear quite even, N is not displayed, my friend will advise me to pour the Eps module water and so I did the gears, whether the module's fault or another reason
  • #7 16515037
    Foxtrott
    Help: 253
    Rate: 944
    Check all the plugs and the condition of the cables at Eps, treat them with Contact Spray and see if you have any chafing. Copper cables start to become dull when they get wet and lose their properties as a guide - the transition can be but it can not be done with proper operation.
  • #8 16516262
    tolo
    Help: 233
    Rate: 1177
    Evidently faulty driver.
  • #9 16516578
    Janek2007
    Rate: 16
    All EPS plugins and connectors have been checked, so I think the driver is still wondering if there are eletkrocewki behind the driver or there is a problem
    Added after 14 [hours] 17 [minutes]:
    We tried to change the EPS driver but on the new module we can not carry out a large teaching, we are shown GS 32 the mechanic claims that the clutch should be changed. Finally, we put in the old driver and the teaching passed with the fact that the car was already 4 hours and cool. It can be the fault of oil in chest as it heats up is too rare and does not raise the chest
  • #10 16518465
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    For the future, however, write what car the question concerns. Actros is already in production for over twenty years, and you can only learn from the 4141 designation that the car is large.
  • #11 16519863
    Janek2007
    Rate: 16
    Mercedes 4141 dump truck 8x6 mp2. Maybe now some help obtained
    Production year 2007
  • #12 16524501
    gucio~1
    Help: 61
    Rate: 314
    Hello. As with old and new drivers, you had gs32 is a good helm. Check sensor installation and sensor.
    It is screwed on the left side of the chest.
  • #13 16525798
    Janek2007
    Rate: 16
    Installation ok only on a hot car teaching does not pass but how cool is ok and the gears sometimes die but as it pours after the drivers water runs and teaching together does not pass is a gs32 error
  • #14 16527334
    Foxtrott
    Help: 253
    Rate: 944
    If you checked the installation with the meter, put it down for a moment, unplug the installation and check with the light bulb - "weaker" wire = less brightness.
  • #15 16531635
    gucio~1
    Help: 61
    Rate: 314
    And what is the resistance of the intermediate shaft speed sensor measured on the controller connector?
The discussion revolves around a recurring issue with the Mercedes Actros 4141 EPS gearbox, specifically the GS32 error that appears during high outside temperatures. The user reports that the gearbox fails to shift, displaying a red GS gearshift failure warning. Various suggestions are made, including performing a computer diagnosis, checking the EPS module and its connections, and inspecting the intermediate shaft speed sensor. The user also mentions that the problem seems to resolve temporarily when the vehicle cools down. Further troubleshooting indicates potential issues with the oil viscosity in the gearbox and the need for a clutch replacement. The conversation highlights the importance of checking electrical connections and sensor installations to diagnose the problem effectively.
