Mercedes actros mp4 1845 Upper radiator grille
matys89 22578 5
  • #1 17124880
    matys89
    Rate: 26
    The error "damaged upper radiator shutter" flashed on the display. The car does not heat up. Manually goes to close the shutter, but after firing it opens again. Where to look for the cause?
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    The lower shutter has a 100% manual lock to keep it closed. I don't remember how it is on the top - but it should be the same.
    Since the diaphragm opens, it is rather functional - it would be best to perform a closing and opening test using an SD computer. Some errors can cause the louver to be forced to the open position - so a general SD test would be a good idea.
  • #3 17126268
    matys89
    Rate: 26
    After connecting to the computer, there is no error anywhere clean everywhere. On Monday I will be removing the front dummy because the beam from the lights has been damaged, I will also check the rest of what it looks like and try to control these blinds, thank you for the hint
  • #4 17780004
    WICI2000
    Rate: 18
    I have a similar problem as my colleague above. MP4 '14 1843. The message "Lower Radiator Visor Not Working" appears. After connecting the computer (Tex) nothing, no errors. The mechanism is functional, I do not know how with the motor, the locks are open.
    Can anyone help me on this topic ?? Thank you in advance!!!!
  • #5 17780456
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    The answer is above: if there are no errors, then connect Star Diagnose and activate both blinds.
  • #6 19605655
    mishop
    Can you please read fault code in truck diagnosis?
