Mercedes Actros 1844 MP3 (2008) - HM Error & Retarder Issue: TEXA Diagnosis & Suggestions
Maciej97PL 26055 6
  • #1 17230723
    Maciej97PL
    Hello, for a long time I see the HM error all the time, texa doesn't tell me much, it normally shows how much air there is in the tanks.
    And from replacing the gearbox with the retarder, when I turn on the retarder, it works as if it were only in 1st gear. I don't know how to approach it because it suits to fix it. Any suggestions?
    The patient is Mercedes Actros 1844 MP3 year of production 2008
    I put HM error photos from TEXA computer and from the car
    • Mercedes Actros 1844 MP3 (2008) - HM Error & Retarder Issue: TEXA Diagnosis & Suggestions img_20180519_172315.jpg (4.48 MB) You must be logged in to download this attachment.
    • Mercedes Actros 1844 MP3 (2008) - HM Error & Retarder Issue: TEXA Diagnosis & Suggestions img_20180519_172306.jpg (4.7 MB) You must be logged in to download this attachment.
    • Mercedes Actros 1844 MP3 (2008) - HM Error & Retarder Issue: TEXA Diagnosis & Suggestions img_20180508_201152.jpg (3.89 MB) You must be logged in to download this attachment.
    • Mercedes Actros 1844 MP3 (2008) - HM Error & Retarder Issue: TEXA Diagnosis & Suggestions img_20180424_181055.jpg (3.92 MB) You must be logged in to download this attachment.
    Seether
    Help: 16
    Rate: 118
    It's good as if you connected SD.
    It looks like an error from the pressure sensor in the left cushion.
    Check the cube and wires, replace the sensor with the other cushion.
    If it is the other sensor, replace it and calibrate it.
  • #3 17231729
    Maciej97PL
    Oki, I will try with the sensor, and what's the SD connection?
    nicram1941
    Help: 22
    Rate: 123
    HM error as a colleague writes, pressure sensor in the left pillow, or beam to HM. Also pay attention to the right side, there are sometimes swapped cables, and Texa does not always tell the truth. In the retarder I would start by changing the oil. Since there are no errors.
  • #6 17256712
    Maciej97PL
    Colleagues, this pressure sensor is what I marked?
    • Mercedes Actros 1844 MP3 (2008) - HM Error & Retarder Issue: TEXA Diagnosis & Suggestions czujnik cisnienia.jpg (3.51 MB) You must be logged in to download this attachment.
  • #7 17256742
    Seether
    Help: 16
    Rate: 118
    yes - it's this sensor :)
✨ The discussion revolves around a persistent HM error in a 2008 Mercedes Actros 1844 MP3, with the user seeking solutions after experiencing issues with the retarder functioning as if in first gear. Responses suggest that the HM error may stem from a faulty pressure sensor in the left air cushion, with recommendations to check wiring and possibly replace the sensor. Additionally, it is advised to inspect the right side for swapped cables, as TEXA diagnostics may not always provide accurate information. For the retarder issue, changing the oil is recommended as a preliminary step since no errors are indicated.
