Golf V 1.4 FSI Oil Warning Light: Sensor Issue, Filter Change, Pressure Check Insights
golfik1.4 6489 13
Why does the red oil warning light in a Golf V 1.4 FSI come on repeatedly for a few kilometers even after the filter was changed and oil pressure was checked?
If the oil pressure is really OK, the repeated red warning light is most likely caused by the sensor wiring/installation or a short circuit in the cable, not by the filter or pressure itself [#16514950][#16515372][#16516608] Check the connection from the oil sensor and the cable harness carefully; one reply specifically pointed to the installation rather than engine speed as the likely source [#16514700] If you cannot trace it yourself, the advice was to have a professional inspect it because it will not fix itself [#16515689]
  • #1 16513572
    golfik1.4
    Golf V 1.4 fsi, the oil sensor lights up for about 5km and goes out it is repetitive. The filter was changed and the pressure checked. Maybe someone will help, what could be the reason?
  • #2 16514114
    sigwa18
    Help: 1194
    Rate: 3357
    Red or orange indicator?
  • #3 16514689
    golfik1.4
    Red indicator light. The turnover has nothing to do here, because whether low or high does not go out, and on other topics I read that at higher it goes out
  • #4 16514700
    lukash3
    Help: 24
    Rate: 133
    I do not know exactly how it is solved there, but if "traditionally" it may just be in the installation somewhere - hence the lack of connection with the revolutions.
  • #5 16514846
    golfik1.4
    The engine works fine, only this light comes on blinks a few seconds and goes out every few km
  • #6 16514950
    lukash3
    Help: 24
    Rate: 133
    I still believe that the installation from the sensor to be checked.
  • #7 16515062
    patryk44gks
    Help: 11
    Rate: 74
    And the computer was hooked up? Something shows some errors
  • #8 16515279
    golfik1.4
    It was attached, no errors
  • #9 16515372
    patryk44gks
    Help: 11
    Rate: 74
    If the pressure has been checked and it is ok
    Either leave it and do not worry, or look for a short circuit, etc. on the cable.
  • #10 16515684
    golfik1.4
    Today the light was on throughout the entire drive, and when restarting when the car was idling, it did not light up until it started to move
  • #11 16515689
    lukash3
    Help: 24
    Rate: 133
    Instead of telling us what's going on, check what I suggested. If you can't, take it to a professional, it won't fix itself.
  • #12 16516143
    golfik1.4
    Everything was done so I am asking for advice, this is probably what the forum is for ;)
    Moderated By CameR:
    Which filter-manufacturer / model designation?
    What pressure value and how long after starting it?
    Describe in detail, preferably in points - what else has been "done", checked on this engine?
    Reg. 3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users.
  • #13 16516608
    patryk44gks
    Help: 11
    Rate: 74
    You already got the advice, but something needs to be done in this direction, you need to check the sensor installations
  • #14 16517161
    golfik1.4
    A lot of stuff has been done and what they wrote to me here but it didn't help
The discussion revolves around a recurring oil warning light issue in a Golf V 1.4 FSI, which illuminates for approximately 5 km before turning off. The user has already changed the oil filter and checked the oil pressure, but the problem persists. Responses suggest checking the sensor installation and wiring for potential short circuits, as the light's behavior does not correlate with engine revolutions. Despite connecting the vehicle to a diagnostic computer with no errors reported, the user continues to seek advice on resolving the issue.
