Volkswagen Jetta - "STOP oil pressure engine off owner's manual"
golin666 36675 6
  • #1 12394038
    golin666
    Rate: 22
    Hello, today I was coming back from the mechanic where I reported a fault consisting in not burning the mixture in my Jetta 2.5 b+g, he uploaded it to the computer and showed 11 errors - regarding the cylinders of the lampda probe and the flow meter, he erased the errors and it turned out that in the first place the flowmeter needs to be replaced - he removed it - however, it turned out that no store currently has it in stock, he put it together as it was and went home, on the way back the following information lit up for me:
    the message dies at a standstill when the box is on "P" and when I drive it appears for a few seconds later it dies and the red oil icon flashes, may it have something to do with the box?
  • #2 12394102
    esprimo
    Rate: 58
    the message clearly reads "ENGINE OIL PRESSURE" did you at least check the oil level?
  • #3 12394135
    golin666
    Rate: 22
    the oil level is normal, it was a little over the min but I topped it up to the max and still the same
  • #4 12394148
    esprimo
    Rate: 58
    barometer and check the oil pressure, most likely it will be; then you will be able to sleep peacefully knowing that the pressure is ok and the problem lies with the electronics (you know what the pressure drop on the pans ends with)
  • #5 12394196
    golin666
    Rate: 22
    ok and now can i drive to the mechanic on my own or just a tow truck? I have about 2 km to it, I read somewhere on a foreign forum that the indicator does not signal it at idle:
    "You didn't get the warning at idle, because the warning (for some odd reason) is disabled below 2000 RPM. That it came on when you moved off (over 2k) is proper operation, and indicates you probably really do have an oil problem - most likely the dreaded clogged oil pump screen. DO NOT DRIVE THE CAR until proper oil pressure has been confirmed with a manual oil pressure gauge. It's kind of normal for the warning to come and go (at first) as the oil pressure will vary with temperature, load, RPM, etc."
  • #6 12394213
    NdYAG
    Help: 11
    Rate: 28
    It was already on the electrode that in VAG cars the pressure lamp is lit by the computer, which only checks the pressure sensor over 2000 rpm from time to time. So you really don't know if you have oil pressure, you can start the car and wait for it to go off, but if there is no pressure then the engine will run dry.
  • #7 12394239
    golin666
    Rate: 22
    when I was in the car now and fired it up to connect it to the vag-com, the oil light did not appear once, tomorrow I will call the mechanic and everything will turn out
The discussion revolves around a Volkswagen Jetta 2.5 B+G experiencing an "ENGINE OIL PRESSURE" warning light. The owner recently visited a mechanic for issues related to the engine not burning the mixture, where multiple errors were detected, primarily concerning the flow meter, which needs replacement. Despite normal oil levels, the warning light persists, particularly when the vehicle is in motion and above 2000 RPM. Participants suggest checking the oil pressure with a manual gauge and caution against driving the vehicle until the oil pressure is confirmed, as a clogged oil pump screen could be the underlying issue. The owner reports that the warning light did not appear when the vehicle was restarted, indicating potential intermittent issues.
