Installation diagram - Is the plus or minus in the light bulb diagram?
creativ_pl 12291 2
  • Clarifying bulb wiring polarity from ignition switch 54
    #1 16518027
    creativ_pl
    Help: 20
    Rate: 25
    Hello, I have a control question because I want to make sure I have such a diagram
    On the front is painted a speedometer with four bulbs. Three of them are connected to each other (blue wire) and this is what I mean, I understand that from the ignition switch (position 54) a plus runs to them, and then the minus goes to the rest of the installation?
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    54 is a plus that goes with these 3 bulbs. One of them is the "slack" indicator, i.e. the neutral gear, where the mass from the switch is given, the second is the charging indicator, which is connected to the voltage regulator, and the third is the indicator indicator.
    Overall, the quality of this scheme is poor.
    The fourth indicator is Road where it is connected to the road fiber and ground.
  • #3 16518574
    creativ_pl
    Help: 20
    Rate: 25
    Just thank you for checking, because after that I thought too much and did not know if I connected the ignition switch to plus bulbs correctly. Best regards.
