SKYPE (installation) - I can't log in - Windows Vista Home Basic
hrabia64 6627 6
  • #1 16519292
    hrabia64
    Please help me with the following problem:
    1) Installing Skype (Windows Vista Home Basic)
    2) Running - a message appears: The content was blocked because it was not signed with a valid security certificate.
    I have Internet Explorer 8.0 installed
    I was looking for a solution to the problem, but no result.
  • #2 16519345
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    hrabia64 wrote:
    I'm installing Skype
    Where did they get from?
    Windows with a license or some "invention"?
    hrabia64 wrote:
    I get the message: Content was blocked because it was not signed with a valid security certificate.
    Date and time correct?
  • #3 16519392
    hrabia64
    Skype downloaded from the producer's website.
    Windows Vista Home Basic bought with the computer.
    The date and time are correct.
  • #4 16519432
    lesławek
    Level 32  
    Help: 190
    Rate: 295
    Install the highest possible version of IE because Skype uses IE to login screen ...
  • #5 16519615
    hrabia64
    I have installed Internet Explorer 9.0 and still do not want to start (same certificate message).
    There is probably no version 10.0 for Vista.
  • #6 16519719
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Install all updates from Windows Update, including certificates:
    http://download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/rootsupd.exe
    or:
    x86 Update for Root Certificates for Windows Vista [November 2013] (KB931125)
    x64 Update for Root Certificates for Windows Vista for x64-based Systems [November 2013] (KB931125)
    Reset IE settings to default.
  • #7 16520143
    hrabia64
    To [Kolobos]: thanks to your suggestion I solved the problem with Skype - thank you very much.
    Below is the configuration on which Skype started:
    Windows Vista Home Basic x86
    Windows Vista Service Pack 1
    Windows Vista Service Pack 2
    Links to download certificates - x86 Update for 'Root Certificates for Windows Vista' [November 2013] (KB931125):
    https://support.microsoft.com/pl-pl/help/9311...-to-get-a-root-certificate-update-for-windows
    http://www.catalog.update.microsoft.com/search.aspx?q=root%20certificate%20update
    Thanks again for your help.
The user encountered a login issue with Skype on Windows Vista Home Basic, receiving a message about a blocked content due to an invalid security certificate. After confirming the installation of Skype from the official website and having the correct date and time, the user upgraded to Internet Explorer 9.0 but still faced the same certificate error. A solution was provided to install all Windows updates, including root certificate updates, and to reset Internet Explorer settings to default. Following these steps, the user successfully resolved the issue and provided links for the necessary updates.
