Connecting SilentiumPC Zephyr 120mm & 100mm Fans to ASRock H55M/USB3 R2.0 Motherboard: Safe?
kysiu811 9996 12
Can I safely connect two case fans to one motherboard fan header with a splitter, and will a 3-pin fan be controllable on an ASRock H55M/USB3 R2.0?
Yes, a 3-pin fan can be plugged into a 4-pin header, but speed control depends on whether the board supports DC mode; if it supports only PWM, the 3-pin fan will run at full 12 V [#16525336][#16525578] The bottom Chassis Fan header is the controllable socket on this board, while PWR_FAN1 is mainly for monitoring the PSU fan and has no speed control [#16525453] The user’s test on the chassis header showed no visible fan-speed change from BIOS levels, so this board likely does not regulate that 3-pin fan there [#16525611] The practical workaround suggested was to use a PWM fan where you want control and a regular 3-pin fan or a separate speed controller for the other one [#16525912]
  • #1 16525288
    kysiu811
    Rate: 20
    Hello. I intend to replace 2 fans on my computer (on the front and back) because the current ones are extremely loud. A friend recommended me SilentiumPC Zephyr , one 120mm on the front to inject air and the other 100mm extruding on the back of the housing. And here my question, or such cluster for 2x 3pin for a pair of zlotys is enough for me to connect these 2 fans to one connector on the main board (PWR_FAN1)? Currently, one fan (at the back) is connected to this input, while the one on the front is connected via MOLEX to the power supply. I read on various forums that for some it works and hook up even 4 fans and I also read that if the board has a weak power section, connecting 2 fans can cause burning.
    My computer's specifications:
    Processor: i5 760
    Graphics card: Radeon HD5770 1GB
    Motherboard: Asrock H55M / USB3 R2.0
    RAM memory: 2x 2GB RAM DDR3 Hynix
    Power supply: ENERMAX PRO82 + EPR385AWT
    Enclosure: Fever AC09A-BK / BK ACHILLES PPFC400
  • #2 16525304
    enhanced
    Help: 963
    Rate: 883
    You have 3 connectors for fans - two above and one below how well I checked your mobo.
  • #3 16525316
    kysiu811
    Rate: 20
    Yes, only the top one is occupied by the CPU cooler. At the bottom there is also one but it is 4-pin and for these fans I need a 3-pin so all I have left is the PWR_FAN1 connector on the board.
  • #4 16525336
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Connect the 3 pin fan to the 4 pin connector, it will fit and will work properly.
  • #5 16525371
    kysiu811
    Rate: 20
    I honestly didn't know that you could connect a 3-pin plug to a 4-pin connector :) One more question, if I connect, for example, the rear fan with a 3-pin connector and the front fan with a 4-pin connector, then both will rotate at maximum speed? I don't want to have it too loud and I think it would be enough if they were working at 50% of maximum speed.
  • #6 16525382
    dt1
    Help: 7315
    Rate: 8292
    I think if you step on, you can check it. I have no idea what controls the fan speed on your board. If it allows PWM or DC regulation on this connector then you will be able to regulate the speed of this fan. If it allows only PWM regulation then you will have 100% RPM (full supply voltage 12V without regulation). After connecting, you can check in the BIOS whether it is possible to set the RPM control mode (sometimes PWM / DC or PWM / DC / AUTO settings). For the 3pin fan, the DC mode is correct.
  • #7 16525418
    kysiu811
    Rate: 20
    I intend to buy the fans so I don't have any way to check it yet. In the BIOS I have the "Chassis Fan Settings" option which I can set to 2 modes "Full on" and "Manual Mode" in which I can set Level 1-9. This setting applies to the 3-pin connector or the 4-pin connector at the bottom of the board and only for fans with the PWM function? Because if only for such I will probably look for a fan that I can control from the bios level so that it is not too loud.
    • Connecting SilentiumPC Zephyr 120mm & 100mm Fans to ASRock H55M/USB3 R2.0 Motherboard: Safe? 20170612_102931.jpg (1.27 MB) You must be logged in to download this attachment.
    • Connecting SilentiumPC Zephyr 120mm & 100mm Fans to ASRock H55M/USB3 R2.0 Motherboard: Safe? 20170612_103019.jpg (1.25 MB) You must be logged in to download this attachment.
  • #8 16525453
    dt1
    Help: 7315
    Rate: 8292
    Chassis Fan is a socket at the bottom of the board and it can be controlled. The manufacturer has not revealed anywhere that it supports the control of 3-pin fans. The upper Power Fan socket is basically used to monitor the power supply fan (by design), it has no speed control.
  • #9 16525500
    kysiu811
    Rate: 20
    So just when I attach a 3-pin fan to this 4-pin connector, will it always spin at 100%? Will it be impossible to regulate the speed or automatically adjust depending on the temperature in the housing? Because if so, I prefer to add a few zlotys to e.g. Arctic F12 PWM Rev. 2 and be able to regulate the rotational speed and possibly buy the other one with 3 pins without regulation and let it spin at 100%.
  • #10 16525578
    dt1
    Help: 7315
    Rate: 8292
    Yes or no - if the board supports DC regulation then you will also adjust the speed on 3pin, if only PWM - then no.
  • #11 16525611
    kysiu811
    Rate: 20
    There is no way to check it? If I'm not sure I will probably buy with PWM regulation. Later I will try to connect the fan (3pin) to the bottom of the socket, which I have on the back of the case and try to change these levels in the BIOS, maybe I can see the difference in speed :)
    I connected this fan to this 4-pin socket at the bottom of the board, changed the levels in the BIOS and did not notice any difference in the fan speed. So probably the 3-pin will not adjust.
    In that case, I will buy a PWM fan on the front and set it at about 50% and on the back I will buy a regular 3-pin fan and let it spin at 100% This is probably the only sensible solution, I hope it will be quieter than it is today.
  • #12 16525912
    dt1
    Help: 7315
    Rate: 8292
    See, you've found a way yourself. Simple and effective. You can also buy a quiet enough fan that its 100% was not bothersome, buy a grommet from molex to a 3-pin socket enabling the fan to be powered from 5V, or you can still buy an additional speed controller for a few zlotys and plug it between the plate and the fan (to choose , to color).
  • #13 16525956
    kysiu811
    Rate: 20
    Thanks so much for your help. I will buy these, I think SilentiumPC Zephyr 120 , they are not super efficient but have a low noise level, I think that they are enough for my computer. If they are too loud, I will buy a speed controller.
The discussion revolves around connecting SilentiumPC Zephyr fans (120mm and 100mm) to an ASRock H55M/USB3 R2.0 motherboard. The user seeks to replace noisy fans and is considering using a cluster to connect two 3-pin fans to the PWR_FAN1 connector. Responses clarify that a 3-pin fan can be connected to a 4-pin connector, but speed control depends on the motherboard's capabilities. The user learns that the chassis fan connector can control fan speed, while the power fan connector does not support speed regulation. Ultimately, the user decides to purchase a PWM fan for the front and a standard 3-pin fan for the back, aiming for quieter operation.
