[Solved] Selection of a quiet and efficient cooling solution for Ryzen 3600
Bluzeczka 10134 5
  • #1 19458903
    Bluzeczka
    Hello, I'm coming today with a question about what cooling solution you recommend for Ryzen 3600. I really want it to cost PLN 300 and be quiet and efficient at the same time.
    EDIT: Corsair 275r airflow case
  • Case clearance determines cooler choice; Grandis 3 or Fuma 2
    #2 19458919
    sunrise84
    Help: 979
    Rate: 877
    It depends on what your case can accommodate.
    Added after 4 [minutes]:
    "budget" and efficient, a copy of Noctua NH-D15
    SilentiumPC Grandis 3 120/140mm
    https://www.x-kom.pl/p/566501-chlozenie-procesora-silentiumpc-grandis-3-120-140mm.html
    Scythe Fuma 2 2x120mm
    https://www.x-kom.pl/p/600310-chlozenie-procesora-scythe-fuma-2-2x120mm.html
    turkuc11
    IT specialist
    Help: 1762
    Rate: 1915
    For your Ryzen, even Fera 5 will be enough.
  • Fera 5 Dual recommended over larger coolers
    #4 19461178
    Roojozzo
    Help: 10
    Rate: 16
    Grandis is a bit overkill, and the question is whether it will interfere with RAM. I certainly wouldn't pack a water cooler. Unless you just see it that way and want it to look like that :D
    Fortis 3, Freezer 34 Duo (although there is a problem with loud fans) is completely enough. Fera 5 dual, which costs PLN 150, is a masterpiece and this is the model I would choose. https://www.x-kom.pl/p/643663-chlozenie-procesora-silentiumpc-fera-5-dual-fan-2x120mm.html
    turkuc11
    IT specialist
    Help: 1762
    Rate: 1915
    Fera 5 has the same temperatures as Fortis and costs less.
  • #6 19488264
    Bluzeczka
    I'm taking fera 5, thanks for the help.
