Man TGX - Adblue Level Display Issue: 0% Despite Full Tank, Replaced Sensor & Potential Cable Break
Krzysiek man TGX 13641 5
  • #1 16526953
    Krzysiek man TGX
    Hello, I have a problem with Man, namely with Adblue it remains 0% in the tank all the time, while it is fully flooded. I replaced the level sensor and the computer continues to display 0% if there may be a cable break somewhere. ???
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    Added after 25 [minutes]:
    Check the supply voltage of this sensor. Fuse f894. Then measure directly at the sensor.
    Pin 1 + 24v
    Pin 2 ground
    And of course, check that everything is alright with the orange cube at the level of the fuel dragon.
  • #3 16527169
    Krzysiek man TGX
    Thank you. Today I will continue to do. I will write if it worked.
    best regards
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    If you need a diagram to review CAN connections, let me know.
  • #5 16527627
    Krzysiek man TGX
    Maniek was repaired, there was no mass, frayed cable from the sensor to the orange cube, thank you once again. Regards
  • #6 16529034
    MAN Electronics
    Help: 321
    Rate: 1718
    I close the topic.
