MAN TGX 18.440 (2009) - Comfort Shift Defective & Adblue Error 5533, Sensor Voltage 5.04V
barczi2008 26094 17
How can I diagnose a 2009 MAN TGX 18.440 Comfort Shift fault and AdBlue error 5533, and where should I look for the cause?
The Comfort Shift fault is most likely in the selector/button wiring or contacts, not the clutch calibration, and AdBlue code 5533 points to the NOx sensor heater circuit [#13775439][#13749816] Diagnose the Comfort Shift in FFR, do a full vehicle scan, and check the cs1/cs2 switch states while moving the grip; the grip/button can be tested with a multimeter and the harness between the grip and FFR should be inspected [#13749581][#13752296][#13759700] In this thread the actual Comfort Shift problem turned out to be a cable inside the knob that made intermittent contact [#13839608] For 5533, check the NOx sensor heating element, its wiring, and the exact FMI/active status, because FMI identifies the fault mode [#13749816][#13752077][#13752296] If the later 03673-08 AdBlue/CAN2 fault also appears, inspect the CAN2/Master-Slave wiring or module, since that code relates to bus deactivation in the CAN2 module [#13839997]
  • #1 13749516
    barczi2008
    Rate: 69
    Hi, I have MAN-ika 18.440 2009 on the tray. Namely, the error with comfort shift and adblue pops up. In comfort shift I can not diagnose tex defect, I have no idea what to look for, and adblue error 5533 sensors have resistance when heated from 200-650 ohms, in the parameters pops up that the sensor before the catalyst voltage is 5.04 V. What to do where to look
    • MAN TGX 18.440 (2009) - Comfort Shift Defective & Adblue Error 5533, Sensor Voltage 5.04V MAN_B____dy_2.png (160.36 KB) You must be logged in to download this attachment.
    • MAN TGX 18.440 (2009) - Comfort Shift Defective & Adblue Error 5533, Sensor Voltage 5.04V MAN_B____dy_1.png (156.49 KB) You must be logged in to download this attachment.
    Use FFR diagnostics with parameters for Comfort Shift faults
    #2 13749581
    MAN Electronics
    Help: 321
    Rate: 1719
    barczi2008 wrote:
    I can not diagnose tex fault
    Buddy having a computer you still have to be able to use it ...
    First of all, you do a general check (which can be seen on the screens) without providing numerical codes, general control will not always show faults from all systems and there is no full description.
    Secondly, for adblue long codes will be signaled (in yellow) despite the working system and you will not delete them.
    Fault shift comfort diagnose in FFR there you will also have parameters, etc.
  • #3 13749770
    barczi2008
    Rate: 69
    There are no errors in FFR, the coupling was calibrated
    Added after 6 [minutes]:
     A mistake came up. Entry comfort shift inputs cs1 and cs2 error 3250
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1239
    The push-button does not contact or break the circuit. With Texe, you can easily test!
    5533 is a fault in the NOx sensor (heating) and what FMI?
  • #5 13751624
    barczi2008
    Rate: 69
    And where is this NOx preheating sensor
    Added after 1 [hours] 17 [minutes]: < br />
     In FMI there are no errors, but he showed up in FFR 03250. And there are several of them in GDK / PDF
  • #6 13752077
    serwis_gh
    Help: 211
    Rate: 1239
    NOx sensor heating failure is related to several FMIs or missing signal or interrupted circuit or temperature not reached, etc. Everything is written on the instrument panel, even the time of the failure. FMI is the identification of the type of fault !!! Short circuit break failure signal failure component malfunction etc. .... Have a nice weekend
    Check comfort-shift switch states and measure grip voltage
    #7 13752296
    MAN Electronics
    Help: 321
    Rate: 1719
    barczi2008 wrote:
    There are no errors in FMI but it showed up in FFR 03250. And in GDK / PDF there are several of them
    Buddy FMI are not bugs but abbreviations and mean Failure Mode Identifier serwis_gh gave several options of the FMI type and so to each error code FMI is added.
    The error you give from the FFR is the same as the FMI ... but since you have a computer, as I wrote earlier, enter the FFR. See the states of comfort shift switches cs1 and cs2 (change of status with the grip) the grip can be measured with a multimeter.
    As for the GDK / PDF vulnerabilities, please provide everyone with information whether the code is active or not and this is also important.
    NOx heating refers to the NOx sensor itself (internal structure)
    Buddy, if you do not cover the above things with all due respect but leave it to the electronics engineer and deal with the mechanics (according to specialization) you will save time unless you want to learn but it will take a lot of time and I do not write it maliciously.
  • #8 13752384
    barczi2008
    Rate: 69
    I have already checked the handle of the transition. FFR error is 03250-08. And I just want to learn from the better
    Added after 33 [minutes]:
     As you said, I checked in the comfort shift parameters the button works, but I do not want to activate the clutch
  • #9 13753657
    ROKADI
    Help: 43
    Rate: 194
    I think you know that comfort shift works while driving, over 10 km / h.
    Moderated By serwisantscani1:
    I've improved my spelling. I pay attention to write posts flawlessly.
    ROKADI - MAN
    Kętrzyńskiego 8, Olsztyn, 10-506 | Tel.: 660-XXX-XXX (Show)
  • #10 13754167
    barczi2008
    Rate: 69
    Yes, I know, but where to look for the fault?
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    Maybe it's worth checking the beam between the grip and FFR ??
    Clutch you write that it was calibrated. And the clutch sensor is working properly ??
  • #12 13763933
    barczi2008
    Rate: 69
    A driving connection as the car returns from the route.
    And the sensor works correctly, the value shows ok.
    svavecone
    Help: 73
    Rate: 456
    I hope you have correctly checked the comfort shift button. You have 3 wires and a button from one connection must turn on the next ... and disconnect previous ones, i.e. "transition" changes from pin to pin after pressing the button.
    Your error is closely related to the button circuit malfunction.
  • #14 13775498
    barczi2008
    Rate: 69
    For sure the wires are good and the knob too
  • #15 13839608
    barczi2008
    Rate: 69
    buddy svavecone it turned out that it was a cable in the knob and once connected once not. But now Adblue has been jumped error 03673-08 something with the line can only what ??
    MAN Electronics
    Help: 321
    Rate: 1719
    barczi2008 wrote:
    it turned out that it was a cable in the knob and once connected once.
    I wrote what
    serwisantscani1 wrote:
    see statuses of comfort shift switches cs1 and cs2 (status change with a grip) the grip itself can be measured with a multimeter.
    3673 CAN 2 module (Master-Slave-CAN)
    Bus deactivation status via the CAN 2 module
    System reaction: Slave control device blocks the amount of fuel injected, the engine continues to run with one row of cylinders (half power)
    Note: For EDC7, C32 Master / Slave is connected to M / S-CAN (connection between master controller and slave controller) on pin A27 and pin A45. In the case of an EDC7 C32 in-line engine with the MAN AdBlue A-CAN system (CAN for additional flue gas treatment), it is connected to pin A27 (lead 191) and pin A45 (lead 192)
    serwis_gh
    Help: 211
    Rate: 1239
    serwis_gh wrote:
    The switch-button does not contact or the circuit is interrupted. With Texe, you can easily test!
    He also wrote but in small letters ...
  • #18 14941986
    barczi2008
    Rate: 69
    Subject to be closed
The discussion revolves around issues with a 2009 MAN TGX 18.440, specifically related to comfort shift malfunction and AdBlue error 5533. The user reports difficulties diagnosing the comfort shift defect and notes that the AdBlue sensor shows resistance values between 200-650 ohms, with a voltage reading of 5.04V before the catalyst. Responses suggest checking the comfort shift button and wiring, as well as the NOx sensor heating failure, which may indicate a circuit issue or temperature problem. The user later identifies a cable issue in the knob affecting the comfort shift, while a new AdBlue error 03673-08 is linked to the CAN 2 module, indicating a bus deactivation status that affects fuel injection.
