Polar PTL 1019: Warnings, Water Intake & Pump Issues, DIY Solutions to Avoid Repair Costs
Jlazarow 7356 16
Why does my Polar PTL 1019 stop with a service warning and F12, and what can I check myself if it won’t start drawing water?
F12 points to a heater fault, and in this case the most likely cause is the heater being shorted to ground. Replace the heater and check the wires and connectors leading to it for damage or moisture [#16536649][#16536907] When fitting the new heater, move over the original temperature sensor from the old heater; the replacement should be straightforward: disconnect the wires, remove the sensor gently, undo the mounting screw, and pull the heater out while pushing the screw in [#16537128][#16537129] If water has run down the tub or casing, also inspect for leaks because moisture can trigger service mode or even reach the motor [#16538746] In the reported case, the machine finally worked after the heater was replaced and the leak was fixed, but the real leak source turned out to be the black rubber drain with a ball in the middle under the tub, secured with wire; replacing that tie wire with a U-bolt stopped the leak [#16544342]
  • #1 16536375
    Jlazarow
    Rate: 12
    I put a wet laundry in the drum and the washing machine did not wash it - the service lit up. I put a smaller amount of dry laundry in it and turned it on, turned it 3 times, the pump started trying to throw away the water, then you hear switching to water intake mode and nothing happens. The main wash light is on, and after a while the service and rinse light are also illuminated. I drained the water from the washing machine and the situation repeats itself, but I am not trying to pump out the water because it is not there. What to do, what can I check myself so as not to incur repair costs with a repairman, because sometimes these are stupid things that you can eliminate yourself.
    I am asking for advice and best regards.
    michal9119
    Help: 8
    F12 - Error related to the heater
  • #3 16536872
    Jlazarow
    Rate: 12
    Heater error and what should I do?
    michal9119
    Help: 8
    In most cases, the heater itself is damaged (breakdown to ground), so replacing the heater should solve the problem. It is also worth checking the wires, plugs, going to the heater, for damage or moisture.
  • #5 16537091
    Jlazarow
    Rate: 12
    I unscrewed the washing machine, looking from the right side of the front of the washing machine, I found what looked like a heater in the bottom of the drum housing, disconnected the grounding and started the washing program. The washing machine started taking water. What should I do now? Ie. try to replace the heater yourself, if so, how to go about it? Thank you for all the previous tips really helped, although at one point I doubted if I would get it going ...
    michal9119
    Help: 8
    While the connectors at the heater do not look flooded, the heater is certainly damaged. The replacement should not be too difficult. It is enough to disconnect the wires, gently remove the temperature sensor, unscrew the mounting screw and pull out the heater while pushing the screw at the same time.
    Kenworth 18
    Help: 2445
    Rate: 3752
    After replacing the heater, please use the temperature sensor from the damaged heater.
  • #8 16537749
    Jlazarow
    Rate: 12
    I don't know what's wrong with her anymore. Now she did not even want to turn on after unplugging the earth from the heater. After cleaning the filters at the solenoid valve and pressing all the cubes and cables and disconnecting the ground from the heater, it finally started and took water, but it did not finish spinning and the service lit up. I noticed that during spinning water comes out from under the apron or collar. But not as many as before, because I pulled it down and cleaned it. But there is water at the bottom of the casing but I'm not sure if the casing is leaking or is it running off the flange. Now the question is whether it is really a heater ....
  • #9 16537929
    michal9119
    Help: 8
    The leak may have soured connections. Is it damp at the connections at the heater?
  • Hydrostat hose has resistance and clicks normally
    #10 16538528
    Jlazarow
    Rate: 12
    I do not think so. It rather ran down the drum housing ... I ordered an apron and a new heater, I will try to replace them. Yesterday I disconnected the hose from the hydrostat, that's what it's called ... And I blew on it, it clicks. I also blew into the rubber tube from the hydrostat and I feel some resistance in it, is it supposed to be like that? Does anyone have any idea what this washing machine is like? Anyway, I'm going to replace the leaking apron and heater and then we'll see ...
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6953
    If it ran down the drum casing, there is a good chance that the engine received a drop of water and it would be enough for it to turn on the service and refuse to wash.
  • #12 16541949
    Jlazarow
    Rate: 12
    Today I installed a new heater and checked if the washing machine would start drawing water with the ground connected to the heater. She started downloading ?. After that, I also changed the collar and put it on silicone. Tomorrow, after the silicone is dry, I will run the entire washing cycle to check for leaks .... I will let you know if the problem has disappeared ... Thank you now for advice, it was actually not difficult.
    Kenworth 18
    Help: 2445
    Rate: 3752
    Temperature sensor installed the original one?
  • #14 16541962
    Jlazarow
    Rate: 12
    No, I put what was in the new heater with this sensor. This is important? I don't throw away the old heater anyway, so if something happens, I will take this old sensor. I looked at the entire washing machine, splashed the contacts, cleaned the can to which the hydrostatic hose goes, but in general there was no muddy place. I am still wondering whether the springs on which the drum hangs should be replaced from time to time ... I looked at the entire washing machine, sprayed the contacts, cleaned the container under the hydrostatic. I am just wondering about one more thing, should it not be appropriate to replace the springs on which the drum hangs?
    Kenworth 18
    Help: 2445
    Rate: 3752
    The old heater can be discarded but not the sensor. If the washing machine breaks the cycle or other problems occur, change the sensor to the original one. However, if it is ok, leave it as it is, but hide the sensor. Why do you ask about springs? Washing machine jumps during spin?
  • #16 16542031
    Jlazarow
    Rate: 12
    I am asking about these springs because it was pouring through the apron, the old silicone peeled off, maybe the drum fell slightly and the old silicone broke due to vibration and the apron became unsealed .... Just wondering if the springs do not deform and lose after some time properties
  • #17 16544342
    Jlazarow
    Rate: 12
    Hello, I have to thank all the people who gave advice, the washing machine is running, I have removed all the faults. Finally, it turned out that it was still pouring below the bathtub, from such a black, rubber drain with a ball in the middle, attached to the bathtub with a wire. I replaced the tie wire with a u-bolt and not a drop of water under the washing machine. I am happy to close the topic and state that it is enough to have an accurate diagnosis of forum specialists and you can fix everything yourself. I encourage women to dare and try their hand at technical fields, it brings great satisfaction, and I ask men to always willingly, as in my case, give advice to women without discriminating against them immediately. Thank you very much ?
The discussion revolves around issues with the Polar PTL 1019 washing machine, specifically related to error codes, water intake, and pump functionality. The user initially faced a service error after attempting to wash wet laundry, leading to a series of troubleshooting steps. Responses highlighted a potential heater failure (F12 error) and suggested checking for damage to the heater and its connections. The user successfully diagnosed and replaced the heater and collar, addressing water leaks and ensuring proper operation. The importance of the temperature sensor was noted, with advice to retain the original sensor if issues arise. Ultimately, the user resolved the problems through DIY repairs, emphasizing the value of accurate diagnosis and community support.
