[Solved] Polar PTL 1109 - Service Indicator Lights Up, Electronics Issue after Warranty, Pump Stops
Dental 7047 13
Why does my Polar PTL 1109 start, run for a while, then stop and light the service indicator?
The thread suggests checking the heater for continuity and leakage to ground first, then inspecting the pressure switch and hydrostatic hose if that does not help [#16737105][#16737221] One reply says the lamp combination points to error F23 [#16738563] The original poster reported that replacing the heater did not change anything, and later that replacing the pressure switch also failed [#16738371][#16745480] A later suggestion is that the hydrostatic reservoir at the end of the hose may be clogged, so the pressure signal never reaches the control [#20032846]
  • #1 16737090
    Dental
    Polar PTL 1109 packed from above, and three months after the warranty electronics went down. Deaf and silent, nothing shines. I got on my feet and worked about 2 or 3 cycles. When attempting the next cycle, it starts, the engine makes a few turns, the pump starts, it works for a while, then it stops and the service indicator lights up. Any suggestions? Has anyone come across something like this?
  • #2 16737105
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    Start by checking the heater for passage and leakage to ground.
  • #3 16737158
    Dental
    Do you think this could be a poor man? OKAY. I won't play measurements. Immediately replace with the sensor. if any more suggestions i will be grateful. Thank you and best regards.
  • #4 16737221
    h jaworski
    Help: 466
    Rate: 717
    If the water does not pick up, you need to check the heater. The sensor is put on old because you do not know what sensor you will get can be from another washing machine and again there will be a problem.
  • #5 16737591
    Dental
    Does not take water. He is silent as a grave.
  • #6 16738186
    Paw_el
    Help: 592
    Rate: 1551
    Only? no other green is off?
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #7 16738371
    Dental
    So it is so. I replaced the heater and nothing. The same as it was. Which signals after calling the SERVICE lamp: Revolutions 400, 1g, 6g 9g, 12g, Sewis and start.
    3.7K solenoid coil resistance is OK?
  • #8 16738563
    nares
    Help: 1515
    Rate: 3387
    Dental wrote:
    1g, 6g 9g, 12g
    Error F23, river topic.
  • #9 16738888
    Dental
    River theme and all that?
  • #10 16738923
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3826
    So different ... :idea:
    Diagram showing error F23 in a washing machine related to pressure switch failure.
  • #11 16738970
    Dental
    TONI_2003! Thank you for the hint. I have already given a new heater (just in case). I will lean today over pressure. I think that I will immediately exchange for a new one. I will let you know about the effects. I have to hurry because my clean clothes are running out.
  • #12 16745480
    Dental
    Unfortunately, DJK. Replacing the pressure switch also failed. I have to keep digging.
    Added after 15 [hours] 28 [minutes]:
    Anything more gentlemen?
    Error F8 / F12: what is this?
    Added after 12 [hours] 38 [minutes]:
    Anyone suggest something more?
  • #13 16778753
    Dental
    Do I have a chance for a hint ??
  • #14 20032846
    homer2.13
    I suspect that maybe the problem was the lack of pressure on the hydrostatic due to a clogged reservoir at the other end of the hose.
The discussion revolves around issues with the Polar PTL 1109, where the service indicator lights up after a few cycles of operation, and the pump stops functioning. Users suggest checking the heater for leaks and ensuring proper sensor functionality. The author has replaced the heater but continues to experience problems, including error codes F23, F8, and F12. There are indications that a clogged reservoir or pressure switch failure may also be contributing to the malfunction. The author is actively seeking further advice on troubleshooting the electronics issue.
TL;DR: Two checks solve most “service light + no fill” cases: “Start by checking the heater for passage and leakage to ground.” [Elektroda, h jaworski, post #16737105]
Why it matters: This FAQ helps Polar PTL 1109 owners diagnose a post-warranty service-light fault where the pump stops and the washer won’t take water.
What does the SERVICE light with several LEDs (400, 1g, 6g, 9g, 12g) mean on a Polar PTL 1109?
That LED set has been read as error F23, which points to the pressure/hydrostat sensing path. It often relates to blocked air paths, wiring to the pressure switch, or the pressure switch itself. One user reported those exact LEDs alongside the SERVICE lamp. Confirm the pressure hose and chamber are clean before replacing parts. “Error F23, river topic.” indicates a known, recurring pressure-circuit issue on this platform. [Elektroda, nares, post #16738563]
My washer won’t take water and stays silent—where should I start?
Documented cases link “no fill + SERVICE” to pressure-sensing or inlet path issues. Verify inlet water is on, screens are clear, and measure inlet valve coil continuity. If coils check out, inspect the pressure hose and the tub-side chamber for sludge. A blocked chamber prevents pressure rise, so the control never authorizes fill. Users described the machine as “silent as a grave,” matching an intake or sensing fault. [Elektroda, Dental, post #16737591]
How do I check the heater safely on this model?
Unplug the washer. Remove heater connectors. Measure heater resistance for continuity, then megger or measure insulation to ground. A ground fault can trigger the service light and halt the cycle. As one expert said, “Start by checking the heater for passage and leakage to ground.” If the heater fails either check, replace it before chasing other faults. [Elektroda, h jaworski, post #16737105]
I already replaced the heater and pressure switch; the error persists. What next?
If parts swaps didn’t help, inspect the pressure circuit end-to-end. Clean the tub-side pressure chamber and ensure the hose isn’t kinked or porous. A clogged reservoir can defeat a new pressure switch by starving it of pressure. Also reseat connectors and look for broken wires around the switch. “Replacing the pressure switch also failed” when the blockage remained. [Elektroda, Dental, post #16745480]
Could a clogged pressure-chamber/reservoir really cause F23?
Yes. If the chamber at the hose end is clogged, pressure won’t reach the hydrostat, and the control flags a pressure fault. One contributor suspected exactly this scenario and called it out as the likely cause behind persistent F23-like behavior after parts replacement. Clean the chamber thoroughly before retesting. [Elektroda, homer2.13, post #20032846]
What is the hydrostat (pressure switch) in a washing machine?
The hydrostat is a diaphragm switch that changes state based on air pressure from the tub via a small hose. It tells the control when the water level is correct. If the hose or the reservoir is clogged, the switch reads wrong. This leads to fill rejection and service faults such as F23. Cleaning the reservoir often restores correct readings. [Elektroda, homer2.13, post #20032846]
How can I read Polar PTL 1109 fault indications without a display?
Watch the LEDs. A user documented the SERVICE lamp together with five LEDs (400, 1g, 6g, 9g, 12g). This combination was interpreted as F23. Note the exact LED set and compare to a code chart for this platform. Consistent patterns help isolate the failing subsystem, like the pressure circuit. Photograph the panel to avoid miscounts. [Elektroda, Dental, post #16738371]
Is 3.7 kΩ OK for an inlet valve coil on this washer?
One user reported measuring about 3.7 kΩ and asked if it was OK. Use it only as a reference, not a standard. Compare both coils; significant mismatch suggests a bad valve. Edge case: a coil can pass a static ohms test yet stick mechanically when energized. If in doubt, bench-test with controlled AC and proper isolation. [Elektroda, Dental, post #16738371]
Why does the pump start, then stop, and the SERVICE light comes on?
The control may initiate drain, then halt when it detects an invalid pressure state. If the hydrostat path is blocked or misread, the controller cannot confirm levels and aborts. Clearing the pressure chamber and hose often resolves the start-then-stop behavior associated with F23-type faults. Recheck after cleaning before replacing boards. [Elektroda, nares, post #16738563]
Should I replace the pressure sensor without testing?
No. As one expert warned, replacing sensors blindly risks mismatches and recurring faults. Verify the heater, check wiring, and clean the pressure circuit first. Parts from other machines may differ, creating new problems. Test the old sensor once the hose and reservoir are clean to avoid unnecessary expense. [Elektroda, h jaworski, post #16737221]
Quick 3-step: how do I clear a clogged pressure chamber on the PTL 1109?
  1. Unplug the washer; remove the top.
  2. Detach the small pressure hose at the tub; remove sludge from the tub-side chamber.
  3. Flush the hose, refit securely, and run a short fill test.
    A clogged reservoir at the hose end is a known culprit. [Elektroda, homer2.13, post #20032846]
Why did new parts not revive my machine right after warranty?
The thread shows that swapping the heater and pressure switch did not cure the fault until the pressure path was addressed. Post-warranty failures often combine minor blockages with protective logic. Focus on cleaning and verifying the hydrostatic path before suspecting electronics. This approach prevented repeated part swaps in similar cases. [Elektroda, Dental, post #16745480]
