Polar PFL1019 - Understanding LED Error Codes with Image Reference - Error Code Guide
miniek. 4572 7
  • #1 16220312
    miniek.
    Rate: 36
    Please check the error code as picture.
    How can you read any help?
  • #2 16220346
    tod.1977
    Help: 65
    Rate: 150
    The washing machine is blocking the door? The heater heats up?
  • #3 16220367
    miniek.
    Rate: 36
    The washing machine locks the door, the programmer module is repaired by a repair kit, and as for the washing machine itself, after the start, the water is pumped out and then silence so you can not check whether the heater heats I disconnected the wire from the yellow-green heater and the same heater, supposedly working 25?, Has no breakdown to ground, checked with a diode meter.
  • #4 16220382
    tod.1977
    Help: 65
    Rate: 150
    I advise you to check the hydrostat and its connection.
  • #5 16223174
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    At what point does the error appear.
    miniek. wrote:
    there is no breakdown to ground checked with a diode meter.
    So it is not checked and there is probably a breakthrough.
    miniek. wrote:
    programmer module after repair by repair kit
    Did the error appear right after the repair?
  • #6 16233438
    miniek.
    Rate: 36
    After turning on any program, the washing machine starts to pump out the water and after a while silence and service pops up and the second LED as in the photo, I have preventively replaced the repair kit plus the triac in the programmer. Today I bought a heater and the same. The hydrostat is in working order, the brushes in the engine have recently been replaced. And then I suspect something on the programmer side or coils in the engine or apparently you can reset the programmer, I will add that it is Whirlpool L2158 ? Coming back to the puncture, it was checked and it just stopped working after the washing program. After turning on again, these 2 LEDs popped out.
  • #8 16240834
    miniek.
    Rate: 36
    Hello, thank you for the hints. The washing machine was repaired, it turned out that the contacts in the hf115f relay burned out after the replacement.
The discussion revolves around troubleshooting LED error codes on a Polar PFL1019 washing machine. The user reports that the machine starts by pumping out water but then becomes silent, displaying an error. Various responses suggest checking components such as the hydrostat, heater, and programmer module. The user indicates that they have replaced several parts, including the repair kit and triac, but the issue persists. Ultimately, it is revealed that the problem was due to burned contacts in the hf115f relay, which were replaced to resolve the error.
