Dishwasher Bosch SPV43M10EU/06: Tap Light On, Water Accumulating, Filter & Pump Checked
mariomw 13590 6
  • #1 16538051
    mariomw
    Rate: 12
    For a month has a problem with the dishwasher. After switching on, you can hear something going on, and after a while the dishwasher seems to stop and make a bake signal. However, after opening the door, the tap lights and there is mostly water downstairs.
    What I did and did not help - clean filter, pump for draining new (replaced) pump not blocked, and drain out. I am asking for help, what else should I check? The dishwasher is two days ok, and in a moment there is a problem as above ...
    Martin_78
    Help: 9
    Rate: 29
    In Bosch the faucet icon indicates a low water pressure error. There may be a clogged filter on the supply hose, but most likely a water flow sensor has failed. Such a turbine with a reed switch. The flowing water drives the turbine, and this via the reed switch generates pulses proportional to the amount of water and pressure taken. greetings
    bruno360
    Help: 14
    Rate: 68
    I would also put on the reed switch. The same was in my washing machine Bosch.
    Repair cost 5-6 PLN, I adopted a window alarm relay. It works as new as two years after this repair. The symptom was that it took too much water and pumped it out over and over again.
    ROBSON33
    Admin of household appliances group
    Help: 465
    Rate: 1714
    Unfortunately, rather to replace the pump
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Water is in the washing chamber, where is the filter? Will the water drain after reset? How robson he wrote, a very frequent cause of problems of this type is the washing pump.
  • Suspected washing pump fault causing recurring drain failure
    #6 16539556
    mariomw
    Rate: 12
    mrice wrote:
    Water is in the washing chamber, where is the filter? Will the water drain after the reset? As Robson wrote, a very frequent problem of this type is the washing pump
    Hello, the water is standing where the filter is. Reset helps water to drain, but after switching on again, it gives up the signal and stands again
    once with water on the filter once without, and of course the faucet shines.
    Pozdr.
  • #7 16547443
    mariomw
    Rate: 12
    Hello, thanks for your help. The dishwasher has been working fine for several days. The reason for the failure turned out to be the water valve to which I connect the dishwasher was "gently" bloated and stoned. After replacing with a new dishwasher, it comes out as new.
The Bosch SPV43M10EU/06 dishwasher is experiencing issues where it stops functioning after a short period, accompanied by a tap light indicator and water accumulation in the bottom. The user has already cleaned the filter and replaced the pump, but the problem persists. Responses suggest that the tap light may indicate low water pressure, potentially due to a clogged supply hose filter or a malfunctioning water flow sensor. One user shared a similar experience with a washing machine, indicating that a faulty reed switch could be the cause. Ultimately, the issue was resolved by replacing a bloated and clogged water valve, restoring the dishwasher to normal operation.
