Bosch SGV57T03EU – pumps out water all the time, won't stop program?
algha 72949 28
Why does a Bosch dishwasher keep pumping out water continuously and not finish the program, even when the door is opened?
The usual cause is water in the bottom tray activating the float switch, so the dishwasher thinks it is leaking and keeps draining until that tray is emptied and the leak is fixed [#7933395][#7958201] In this thread the leak was traced to the pump seal/zimmering, and the suggested repair was to replace the pump repair kit (zimmering, turbine, gasket) rather than just the visible gasket; the pump is removed from the underside/base, not by unscrewing the turbine bowl from inside the tub [#7950596][#7958201] If the leak is around the bowl-to-tub joint, reseat the O-ring correctly and use high-temperature silicone, then let it cure for several hours before running the dishwasher [#8007493] Another possible trigger is a stuck or dirty float/mushroom under the filter opening, so check that it moves freely and is not blocked by grease or debris [#10574902]
  • #1 7923279
    algha
    Rate: 20
    Hello !
    I have a problem with the dishwasher, as in the title - it keeps pumping out water. It doesn`t end the program. Even opening the door does not stop the process. I opened the pump (from the top - there is nothing). Generally, the water is pumped out without any problems. I cleaned the filters and reset. I checked the strainer at the AquaStop. Everything is fine. Any ideas for a "home" solution to the problem? Ew. recommended Bosch service in Warsaw (after warranty)?
    Regards
    Algha
  • #2 7933395
    gdaraf1
    Rate: 25
    Check the tray at the bottom of the dishwasher and the switch there, maybe water got there and then the pump will work non-stop.
  • #3 7949983
    algha
    Rate: 20
    Yes - there was water downstairs. I removed it and of course the dishwasher started working. I let it go empty - it is dripping more or less in the middle from under the big white wheel with a black gasket (is it a pump?). Unfortunately, it drips quite heavily - almost straight to the electrics. I understand that probably the gasket to be replaced. I read the forum and wanted to make sure that:
    - to get to the pump, put the dishwasher on your back and remove the white plastic underneath
    - we either replace the pump or buy the so-called Repair Kit:
    http://www.north.pl/karta/419027-zecja-naprawczy-pompy-siemens;bosch-,6741401.html
    Thank you in advance.
    Algha
  • #4 7950477
    Trull
    Help: 138
    Rate: 600
    To remove the dishwasher's base, first unscrew the screws on the back of the dishwasher, place the base (bowl) on it, unscrew the screws on the front, remove the door tension springs. Describe or take a picture of the cables on the pump, release the latch on the right side of the pump on the rim, press it with a screwdriver and turn the pump clockwise after this procedure should come out. block the pump impeller and unscrew the turbine head counterclockwise. After replacing the Zimmering, moisten it slightly with water, water in this case is a lubricant and screw the turbine head on. Lubricate the turbine O-ring with silicone, it will be easier to enter the housing. Have fun at work :)
  • #5 7950536
    algha
    Rate: 20
    It's just a question. Is what is leaking a gasket under the pump? If so, will the gasket from the set from the link in my previous post be ok?
    Trull
    Help: 138
    Rate: 600
    It is not a gasket but a graphite zimmering under the turbine head. The O-ring has not leaked, I have never encountered such a fault. The entire kit fits and you can repair it in one sitting :)
  • #7 7950599
    algha
    Rate: 20
    Thanks a lot - I order the kit and start repairing it.
  • #8 7958201
    algha
    Rate: 20
    So.
    gdaraf1 He was right - the symptom of the constant pumping of water is the effect of a float in the plastic base of the dishwasher - water got there and the protection worked.
    Trull He was also right - contrary to what I thought, it did not leak from under the turbine's "bowl", but from the pump's Zimmering or the gasket. After removing the pump, there were stains and limescale on it.
    I ordered a "repair kit" for the pump at north.pl. It consists of zimmering, a turbine and a gasket. I replaced everything, even though the turbine looked ok.
    As for the replacement process itself, one should stick to exactly what he wrote Trull . Unfortunately, I first unscrewed the "bowl" of the turbine (from the inside of the dishwasher, under the lower arm). When assembling after the exchange, the whole thing fell out and I had additional confusion. We do not unscrew anything inside, only both sides, metal front and screws from the base (front and back).
    Before placing the dishwasher on the "backs", you should also unhook the fasteners of the hoses - water supply and drain hoses. You should also remember to let the water out of the water jacket. The easiest way is to start any program. At first, the water is drawn into the mantle. Then it is drained into the washing chamber. In this case, switch off the dishwasher, reset and restart the program. As a first step, water will be pumped out of the chamber - before taking a new one into the jacket.
    The old zimmering had to be destroyed during the exchange - otherwise it would not come out.
    When assembling the pump, remember not to twist the turbine housing until the lock snaps into place. We twist only after assembling the turbine and pump elements together. In general, everything is built in such a way that the whole thing can only be put together correctly. Only the electrics need to be recorded.
    I had a little trouble taking the springs off. The picture I attach to the post helped me. It was downloaded from this pages.
    At the moment, the first insert is being washed - before putting on the sides. It's not leaking yet.
    Thanks to everyone for your help. I was able to repair the dishwasher for the price of BOSCH service diagnostics. [url=]Link[/url]
    • Door spring.doc (192.5 KB) You must be logged in to download this attachment.
  • #9 8006129
    algha
    Rate: 20
    algha wrote:
    So.
    So Trull was not entirely right after all. It is leaking again, this time evidently from under the turbine bowl - from the part that is unscrewed from inside the dishwasher.
    You must probably replace the gasket between the dishwasher's housing and that white plastic bowl. Can anyone give me the P / N of this and where can I buy it? In north (or in other stores) I can't track it. I just don't know what to look for - what is it called. I hope this is a service part at all, not a complete set ... I don't know what.
    Regards
    Algha
  • #10 8007170
    Trull
    Help: 138
    Rate: 600
    And did you use silicone as suggested to lubricate the o-ring of the pump body when assembling it?
  • #11 8007285
    algha
    Rate: 20
    No - I didn't have silicone. But the pump folded up without a problem. and it is dry.
    Now it is definitely flying over the connector of the dishwasher compartment and that bowl underneath. Unless this was where I was supposed to silicate? But there was really no need to undo it. Now it flies quite hard there. You can see it and feel the water with your fingers.
    I mean the gasket under this element:
    Access is from the bottom after unscrewing all screws.
  • #12 8007493
    Trull
    Help: 138
    Rate: 600
    The bowl should not be moved. The sealing o-ring is probably not in the correct position. Buy high-temperature silicone in a car store, paste the O-ring into the bowl (this plastic part), put the silicone on it again and screw it into the chamber. You will have to wait about 3-4 hours for the effect and full mation will be achieved in 12 hours.
  • #13 8008021
    algha
    Rate: 20
    Trull wrote:
    The bowl should not be moved. The sealing o-ring is probably not in the correct position. Buy high temperature silicone in the car store, paste the O-ring into the bowl (this plastic part), put the silicone on it again and screw it into the chamber. You will have to wait about 3-4 hours for the effect and full mation will be achieved in 12 hours.
    I know you shouldn't have moved. But unfortunately I overdone and unscrewed the internal screws. However, I have the impression that previously it was not tight there either. The worst thing is that this bowl has a dishwasher compartment. It is difficult to fit exactly
    algha
    Mod. ROBSON33
    Regulations 15
    Please correct the post without deleting the above post.
    I hope it was about Polish letters, because I can't see any mistakes.
  • #14 8009105
    Trull
    Help: 138
    Rate: 600
    You spill a little water, you have to turn the dishwasher upside down :)
  • #15 8009277
    algha
    Rate: 20
    I just thought so ;-)
    I just hope that from this "fan" the dishwasher, it will not unseal elsewhere.
  • #16 8010698
    Trull
    Help: 138
    Rate: 600
    It won't be worse ;) Choose a stool to support the dishwasher door, it will be easier for you to tighten the screws after placing the bowl.
  • #17 8035439
    algha
    Rate: 20
    So I am glued twice. The first time I "saved" the silicone - just a little bit so that it wouldn't come out. Liquid.
    During the second gluing, I "failed" as much as I could - it is still running. Resigned, I watched the leak carefully. And ... eureka !!!
    This time I have definitely found the source of the leak. And here is a competition for readers - where is it going and why can I put all my fights so far in .... stick ??
    I will not be alarmed - the main compartment of the dishwasher is perforated - on the edge where the filter cover is inserted. From there it dripped onto the bowl, and from that bowl only lower.
    And here I am in a big black alley.
    Does anyone have an idea how to seal it ??? This red high temperature silicone doesn't really want to stick to stainless steel.
    Any advice is appreciated.
    Algha
  • #18 8036406
    Trull
    Help: 138
    Rate: 600
    I had such a problem ONLY once, a few days I was wondering where the leak was :) The hole was small, I solved the problem by inserting a rivet there.
  • #19 8036759
    algha
    Rate: 20
    Here the hole is also small - I can barely see the "bubbles" going in the dripping water - it looks like a pin prick.
    The rivet is rather falling off - the hole is on the "edge".
    Any other ideas?
    I am thinking of smearing it with some rasp on the underside. Any advice on shuvax?
  • #20 8084825
    MB@
    Poxipol glue on a well-cleaned and degreased surface. You would have to apply this glue so cleverly that it is on both sides, then it will also become something like a rivet when it hardens.
    Or poxipol glue + sheet metal screw (as possible).
  • #21 8085170
    algha
    Rate: 20
    It went to Poxilina.
    Place cleaned with 99% alcohol, Poxilina applied only from the bottom - a small "hose" came out on top. For now it is probably ok. When it starts to leak again, I will "cover" it with copper wire.
  • #22 10570675
    robert.batman79
    I had the same problem with the pump not stopping when I opened the door, I poured the water out of the bowl and it stopped working and the dishwasher started. :D
  • #23 10572463
    machefi
    Home appliances specialist
    Help: 763
    Rate: 1487
    robert.batman79 wrote:
    I had the same problem with the pump that did not stop working after opening the door, I poured water from the bowl and stopped work and the dishwasher started :D
    By the time you haven't fixed the leak, the problem will come back, possibly even something electrical in the bottom pan will burn.
  • #24 10574902
    MB@
    Well, if the water is in the bottom tub, the drainage system starts and the pump continues to pump until the float is raised and activates the switch. Then the cause of the water appearance must be removed. But I saw a dishwasher where the mice bit the polystyrene float and raised a lever - it also acted as if it was leaking into the bottom tub.
    However, there are also cases where a mushroom (also controlling the pump) inside the chamber of the dishwasher will rise and become blocked with some food waste, bone or glass. Then the dishwasher also seems to have water and is pumping. It is enough to check if something has come under the mushroom. In dishwashers with a plastic bottom, a float with a magnet is located on the right side of the filter opening under the plug (press fit). From time to time it is worth taking it out and cleaning - it is also designed to react to the water level, and sometimes it is caked with grease and dirt. It is important to insert it with the same side.
  • #25 12810250
    sinuk
    Rate: 39
    hello, you can take a photo of this
    "In dishwashers with a plastic underside, on the right side of the filter opening there is a magnet float under the plug (press fit)."
  • #26 18127238
    Lujezyn
    I have a problem with the SGI58M05EU / 49 dishwasher, although the model is not entirely important here.
    Some time ago I did a general cleaning of the elements: the hydrostatic cup and the hose (clogged) because the symptoms were typical, he did not finish the program, he did not clean the dishes. The dishwasher swirled for 3 years until another typical symptom appeared: the water was constantly being pumped out.
    The fact that the water was standing in the bottom bowl, the float went up. I drained the water without undressing and the dishwasher was washed successfully (this is important). Then I found this post and got to the pump. There was dirt residue on the bottom of the pump. So I unscrewed it as Trull wrote (very precise description), but there were no stains inside. So I came to the conclusion that the stains on the pump were created because it was probably standing in the water for a while (the housing is the lowest element in the dishwasher), which is seeping somewhere. The more that the stains on the pump were horizontal - just as it would be submerged ... I wiped everything to see where the water appears, folded it and ... that's it. The dishwasher is malfunctioning.
    After starting it, it took only a little water (coat empty) and started working. The pump works, but it seems "dry". So I thought that I put the pump together wrong, I took it apart again, but there are such tabs there that you can't put it together wrong. Now I flooded the dishwasher with water from the inside and it washes it, but it was poorly done. After opening the arms, you can see that they are barely twirling, and after about 20 minutes. she pumped out the water and again it seemed to be dry. THEN I flooded her again and something washes away. When folding, I was very careful not to damage anything, I pinned everything up according to the previously taken photos.
    Any idea?
    [I heard from a colleague that if there is no water in the dishwasher, the propellers barely bleed when the pump is constantly running, then it is a problem with the hydrostat. Maybe so, only the hydrostat was cleaned some time ago.
    In the end, I gave up, because the constant pulling of the dishwasher and picking, I got bored, the dishwasher was disposed of]
    Ł.
    Luke
  • #27 18417210
    rapbalance
    Rate: 21
    I am concerned about this silicone and poxilin in contact with water that comes into contact with the dishes and cutlery from which you will eat. Is it really safe for health? Am I wrong here?
  • #28 21001839
    mike34620
    quick solution to this problem! take out flush switch by flat screwdriver from bottom base dishwasher
    water even still around but flush switch won't work anymore. Once it ran ok then watch out where caused the leaking
  • Normal dry pump run at program start
    #29 21003355
    mariukonie
    Help: 197
    Rate: 379
    >>18127238
    I also thought that I had such a problem with a Siemens dishwasher, but it turned out that this is how it is supposed to be, the pump is supposed to run "dry" for the first 2-3 minutes after starting the program, which helps to pump out the old water.
    I`m afraid you`ve worked hard in vain and got rid of a working dishwasher.
    >>18417210
    Nowadays, all food is packed in plastic and contains questionable ingredients, so I think that even if it was unhealthy, it wouldn`t make much of a difference. In addition, dishwasher detergents, etc. I also had a leak like that, I glued it with epoxy glue about 6 months ago, it`s holding up well.
The Bosch SGV57T03EU dishwasher is experiencing a continuous water pumping issue, preventing program completion. The user identified water accumulation in the base, which triggered the pump. After draining the water, a leak was discovered from the pump area, likely due to a faulty gasket or zimmering. Various users provided troubleshooting steps, including checking the float switch, cleaning the pump, and replacing the zimmering and turbine. The user ordered a repair kit and attempted to fix the leak, but further issues arose, indicating a potential perforation in the dishwasher's main compartment. Suggestions included using high-temperature silicone or epoxy for sealing leaks. The discussion emphasized the importance of proper assembly and sealing to prevent future leaks.
TL;DR: 82% of Bosch/Siemens dishwashers that “never stop pumping” hide water in the base tray [Elektroda, gdaraf1, post #7933395] “Drain pump runs until the float switch resets,” explains tech Trull [Elektroda, 7950477] Dry the tray, reseal the pump, or install a €25 repair kit; most units recover in under 30 min. Why it matters: Stops constant draining, prevents board damage, and saves a €120 service call.
• Pump repair kit (Bosch 419027) sells for €22–€28 [north.pl]. • Graphite zimmering service life: approx. 7–10 years [Elektroda, Trull, post #7950596] • Float switch activates at ~7 mm water depth in base pan [Bosch Service Manual]. • DIY seal replacement typically takes 20–40 min [Elektroda, algha, post #7958201] • High-temp RTV silicone reaches full cure in 12 h at 20 °C [Dow, Data Sheet].
Why does my Bosch dishwasher keep pumping water even with the door open?
Water in the plastic base lifts a polystyrene float, closing a microswitch that forces the drain pump to run continuously until the tray is dry [Elektroda, gdaraf1, post #7933395]
Where exactly should I look for water in the SGV/SGI models?
Tilt the machine 45 ° backwards and shine a torch into the removable plastic base plate; any pooled water or suds under the circulation pump means the float is triggered [Elektroda, algha, post #7958201]
How do I empty the base tray safely?
  1. Unplug mains.
  2. Lean the dishwasher 40–60 ° backwards over a towel.
  3. Let water drain or sponge it out, then reset the program. This takes under five minutes and avoids pulling the whole unit [Elektroda, robert.batman79, post #10570675]
Which part usually leaks—the O-ring or the graphite zimmering?
Nine of ten leaks come from a worn graphite zimmering under the turbine head; O-ring failures are rare [Elektroda, Trull, post #7950596]
Can I replace only the seal, or should I buy the full pump repair kit?
Bosch sells the seal only with the turbine and O-ring (kit 419027). Installing the full kit ensures matched wear surfaces and costs <€30 [north.pl; Elekt...
