Comparing TCL 55C70 TV and Diamond Grinding: Detailed Analysis and Review
6300 5
  • #1 16544463
  • #2 16546104
    ar2d2
    Help: 6
    Rate: 17
    Recommended as 4K and input lag again for FHD only measured. What contrast is the value of 12900 (Rtings measured the highest value on LCD LED around 6500: 1. Even TV for a dozen thousand does not exceed this limit). 50 Hz matrix last year such models were not recommended by a dear seller and this year this change ( I wonder how TCL suddenly got such a liquidity system
    traffic has improved :)
  • #3 16546243
  • #4 16546415
    ar2d2
    Help: 6
    Rate: 17
    The manufacturer provides a contrast Ratio - 4000 for this model. So what's the 12900 contrast? Maybe you've tested another model? Or maybe someone doesn't know how to use Calman very well?
    The fact that 50Hz matrices are used is not a problem, other manufacturers have refined motion compensation systems. In previous TCL models they were poor. Also in the recalled Philips in the 6561 model, despite the 100Hz matrix, the fluidity is poor at the level of the 50 Hz matrix (unfortunately I have convinced myself how bad this TV is).
    Anyway, the forum to which the link leads is quite a lot of posts about the fluidity of TCL models and even in the topic about P60 appeared that it is not quite good.
  • #5 16546425
  • #6 16592862
    Pablo1964
    Moderator
    Help: 507
    Rate: 642
    I deleted posts with no substantive value. I am closing due to the low level of discussion.
