Philips PUS6561 vs PUS7303: Which 55 4K Smart TV for 5x4m Living Room? Price & Features Comparison
TheCzape 4710 3
  • Need for 120 Hz and PS4 gaming support
    #1 17234780
    TheCzape
    Hello, I have a problem with the choice of TV for the living room. Similar price, but which will be better? Philips PUS6561 or Philips PUS7303?
    1. How big is the room where the TV should be? - 5x4m
    2. How far are we from the TV screen? - about 3m
    3. How many people sit in front of the TV? - 2
    4. Are we sitting in front of the screen or sideways to the screen? - straight out
    5. Is the TV supposed to stand or hang? - stand on the dresser
    6. How does the sun shine in the room? - south of the window
    7. What is your TV currently? - Blaupunkt 40 inches full hd
    8. What do we want the TV to have? - Smart TV, 4K image, 55 inches
    9. What signal will be connected to the TV? - cable TV
    10. What devices? - sometimes a flash drive or a phone
    11. How many hours a day does the television work? - about 8 hours
    12. Does it happen that you watch only one program for several hours? - no
    13. What kind of programs do you watch the most? - everything in general
    14. Are you going to surf the internet? - Yes
    15. Do you intend to play games - if so, how much% per day? - plans to buy ps4
    16. Brand preferences? - Samsung, LG, Philipps
    17. Size preferences? - from 55 inches up
    18. What annoys you on TVs? - smudge
    19. Do you watch more in the evenings or during the day? - rather evenly
    20. Up to what maximum amount do you plan to buy? - +/- PLN 3,000
    21. How often do you change TV sets at home? - few years
    22. Do you use internet applications often? occasionally
    Which TV should you choose? What are the pros and cons of the TVs above? The Philips 6561 has a 120Hz refresh rate, that's a big plus. In the future I plan to buy a PS4, so that tv must be suitable for playing. I also found the Manta 65LUA58L Emperor, 65 inches, price around 2500 PLN, sounds interesting. I read a bit about this tv and opinions get different. I would like to ask you to comment on this TV too. I would prefer a larger tv, but maybe 55 inches in Philips will be better. Or maybe you can provide some other suggestions for 55 inch TVs for around 3000 PLN worth considering. Thank you in advance for all statements.
  • #2 17240056
  • #3 17241109
    lesmian45
    Level 19  
    Help: 19
    Rate: 17
    Please note that the Philips 7303 in turn has a VA matrix. I would take a newer model. Algorithms that improve image smoothness are now so good that you can actually skip native refresh.
  • #4 17242660
    Mariano11
    Help: 57
    Rate: 43
    7303 - definitely yes. Plus ambilight, but you rather know it, since you bet on Philips :) .
