Tv65 Showdown: Sony KD65XF7596 vs LG SK8100 - Performance, Android Issues, Brightness & Contrast
BONO 3297 5
  • Concerns about Android issues and panel brightness
    #1 17576951
    BONO
    Help: 74
    Rate: 18
    Hello, I'm going to buy Sony BD65XF7596 in BF
    Has anyone tested it because there are opinions on the net
    different, that is cropped on android etc.
    I was also thinking about the LG 65SK8100LLA but apparently the matrix is not interesting, poor in its brightness and contrast.
    TV for nc + and videos from youtube and usb.
    Samsung altogether falls out because there is no divix and no amp output via a headphone jack.
  • #2 17577199
    Ludwik XVI
    Help: 1325
    Rate: 788
    Better matrix in Sony - here LG has nothing to look for with its low-contrast IPS.
    Android is an android - on 2GB hardware it will be cut and that's it. There will be no miracles here.
    However, if you limit yourself in installing the application and keep the system clean, it will be ok.
  • #3 17577368
  • #4 17579249
    BONO
    Help: 74
    Rate: 18
    Bought Sony KD65XF7596 on BF for PLN 3850
  • #5 17580015
  • #6 17594381
    HAKRYS77
    Maybe sk8100 does not have such a bright matrix but the image from IPS and a good IPS class is a lot better than on this Sony and 100hz.
