peugeot 607 2.2 hdi - the key after turning does not turn the starter
handa 8892 5
  • #1 16544200
    handa
    Hello, the problem is that after inserting the key in the ignition, all the basic messages are lit, everything works and yet it does not turn the starter - there is deaf silence. Starter ok, for "push" the car lights up. connected "briefly" lights up. All fuses checked (ok). Could someone help me? is there a possibility that something fell in the ignition? Or is it the car's fault? Please, give me a hint.
  • #2 16544218
    leonov
    Help: 1039
    Rate: 2248
    Since
    handa wrote:
    "briefly" lights up
    that is, a damaged starter solenoid or ignition does not energize it.
  • #3 16544322
    Pawel wawa
    Help: 1262
    Rate: 4433
    Probably a vending machine box, but a colleague does not deign to write.
  • #4 16544355
  • #5 16544374
    Pawel wawa
    Help: 1262
    Rate: 4433
    georgesgr wrote:
    So not BVA.
    Actually, you're right, I looked at the author's older posts and manual gearbox. It remains to be checked on foot. They were produced for 11 years and there were changes in the installation, but I would start with a starter relay.
  • #6 16544379
