Play LTE Unlimited Data Offer for 30 PLN: True or Throttling After Certain GB Usage?
Hexi 5154 19
Will Play's LTE unlimited data offer really be unlimited, or will the speed be throttled after a certain amount of data is used?
Play's "unlimited" LTE offer is not truly unlimited; posters expect a speed throttle after a data threshold, so the safest answer is to wait for the official regulations [#16545825] The linked regulations page was provided, and forum members note that Play's existing plans already use caps such as 10 GB or 100 GB followed by a 1 Mb/s funnel [#16545970][#16547643] More generally, they say Polish LTE "unlimited" offers usually contain a clause allowing speed reduction after some usage, often around 60 GB or 100 GB [#16575940][#16597988]
  • #1 16545734
    Hexi
    Rate: 11
    I look so on the internet, and I noticed that play intends to introduce LTE internet without GB limit, message from today. For a subscription for 30 PLN.
    What do you think Will it be true or a small print that after some GB the internet is slowing down?
    Regards.
  • #4 16545825
  • #5 16545970
    matek451
    Help: 4352
    Rate: 5808
    Today regulations will appear and the offer will turn out. In the voice offer on phone cards, there is probably no limit of 10GB, 1Mb / s funnel, on an additional internet card it will probably be 100GB and then 1Mb / s. In this respect, nothing will probably change. The offer is already on the site, on voice cards as before 10GB and 1Mb / s funnel. On the additional 100GB internet connection and then the funnel. The additional costs in the formula are 3x5 PLN = 15 PLN, in DUET 2x10 PLN = 20 PLN and SOLO 20 PLN. This is due to the difference in subscription prices with and without an internet card in individual tariffs.
  • #6 16546402
    Hexi
    Rate: 11
    It is a pity, because it writes in small print that after 100gb the speed is limited, at most I will take this t-mobile because soon I have the end of the contract.
    I just have a question, this unlimited internet max from t-mobile has a limit of e.g. 100gb or something? Because someone wrote that after 1000gb it slows down to 2mbps, I don't know if it's true.
  • #7 16546525
    m.jastrzebski
    Help: 679
    Rate: 865
    ALL LTE internet offers in PL have one way or another in the regulations about mandatory or possible reduction of speed. For one it will be 60GB, for another 100GB. Somewhere in a goat, someone took 300GB and the funnel did not jump. Which doesn't mean that it won't start in a month, two or a half years. Since this entry was introduced with a "small print", it seems for some purpose ....
  • #8 16546809
    Hexi
    Rate: 11
  • #9 16547048
    matek451
    Help: 4352
    Rate: 5808
    In the offer of T-Mobile with equipment for 79.99 there are no limits although in the regulations the operator stipulates that if you threaten the network it will cut to 16Kb / s. In general, transfers of several hundred GB are the norm, without a funnel. Only B525 from the equipment. The 100GB limit and 2Mbps funnel are on offer for 59.99.
  • Asking about T-Mobile speed and trial availability in Kościerzyna
    #10 16547384
    Hexi
    Rate: 11
    What will be the speed of t-mobile internet without a GB limit in Kościerzyna in the middle of the city?
    Can you take them for example for a few days for free and check?
  • T-Mobile offer has no hard cap, only FUP
    #11 16547457
    m.jastrzebski
    Help: 679
    Rate: 865
    And, as usual, probably the operator does not define "network threat" in the regulations.
    I remember LTE without limits from PLUS / CP. There were also no limits, there was no indefinite FUP. How good it was people pulled hundreds of GB. then it turned out that FUP had to be applied immediately after the package. As long as there is such a provision in the regulations, there will really be no LTE without limits.
  • #13 16575940
    DiZMar
    Help: 2892
    Rate: 6652
    The "unlimited" offers are without any data limit but with a limit on download and upload speed after exceeding the assumed amount of data in a monthly settlement period. So far, no mobile operator offers internet at maximum speed with no limit of transmitted (received + sent) data.
  • #14 16575960
    Hexi
    Rate: 11
    t-mobile for PLN 80 ma
  • #15 16576041
    DiZMar
    Help: 2892
    Rate: 6652
    80 PLN / month for 1 SIM card without international calls (not to be confused with roaming) is a cosmic price.
  • #16 16591978
    Marcin Z.
    Help: 18
    Rate: 65
    At present, Play is limited to 10GB internet. After using, you can run another 10GB for 5 PLN.
  • #17 16591993
    DiZMar
    Help: 2892
    Rate: 6652
    There are also no limit but zlejkiem up to 1 or 2MB / s after 10GB. Restoring speed for the next 10GB is also at different prices often higher than 5 PLN.
  • #18 16597969
    darekk1993
    Unfortunately, there is no transfer limit but there is a speed limit ...
  • Unlimited LTE plans are speed-limited in practice
    #19 16597988
    m.jastrzebski
    Help: 679
    Rate: 865
    And I write it all the time. There are no LTE offers in PL at the moment, where the small print on page 7 of the regulations is not written that the operator can limit the speed or obligatorily lower it after finishing the package on "unlimited internet" ;-) It is often limited to unusable speeds, which in practice means the end of the net.
    As long as they leave the gate, you don't know the day or the hour. One will jump into another. One never jumps on another every month. It hasn't jumped you for half a year, but it can start if it's the operator's interest to reduce data usage.
  • #20 16606258
    darekk1993
    Let's answer honestly, how many average users read these regulations before signing the contract? :) As long as people agree to such flowers, operators will use it.
The discussion revolves around Play's announcement of an LTE internet offer priced at 30 PLN, purportedly without a data limit. However, participants express skepticism regarding the actual terms, suggesting that speed throttling is likely after a certain data usage threshold, typically around 10GB or 100GB. Users reference similar offers from other providers, such as T-Mobile, which also impose speed limits after exceeding specific data amounts. The consensus indicates that while the offer may appear unlimited, the fine print often reveals conditions that lead to reduced speeds, particularly after reaching a defined data cap. Users are encouraged to review the service regulations carefully to understand the implications of such offers.
