Zafira B 2006 1.8 Z18XER Wiring Diagram: Engine ECU FGP 12992406 XU Installation & CAN Network
bolekf2 18798 2
  • #1 16546536
    bolekf2
    Rate: 258
    Hello, I need a wiring diagram for the Zafira Z18XER as in the topic.
    It is primarily about the installation diagram from the engine ECU,
    ECU:
    FGP 12992406 XU
    S0600110
    SIEMENS VDO
    5WK9 395
    6 03 13 13 30 5
    SIMTEC75.1
    The controller has 2 plugs, E and B. Both plugs have 64 pins.
    And the CAN network diagram, because there is a complete lack of ECU CIM communication and the engine does not start.
    We can connect with the CIM module, nothing can be read from the ECU.
    Permanent error in CIM regarding lack of communication.
    best regards
  • #3 16560021
    bolekf2
    Rate: 258
    There was no power on the ECU, now everything is fine. best regards
