Opel Zafira B UEC Module: Mentioning, Number Coding, and Appending Process
BoroPiotr 13815 9
How do I code a replacement UEC module in a Zafira B when the part numbers are the same?
The UEC usually only needs the correct module installed and the car options set, but some users report that a replacement also requires entering your VIN and configuring the equipment [#16231893][#17161202] Others say there is no special UEC login or component protection, and that it works after swapping the box, with only settings such as daytime running lights needing activation [#16232392][#17162774] It is also worth checking the alpha code on the sticker and making sure any fuses/options present in the old unit are transferred to the new one, such as AHL or automatic gearbox-related fuses [#16232392][#17162774] One reply adds that the PIN/code situation may depend on the car: some vehicles have it in the UEC, others in the rear REC module [#19295221]
  • #1 16231879
    BoroPiotr
    Help: 17
    Rate: 52
    Hello, how do I mention the UEC module in zafira because the same numbers require coding appending?
  • #2 16231893
    leonov
    Help: 1039
    Rate: 2248
    Yes you must enter your VIN and configure it for your equipment.
  • #3 16232118
    Jurek220
    Help: 159
    Rate: 256
    First of all, you still need both modules.
    Pozdr.
  • #4 16232392
  • #5 17159066
    jack6868
    Rate: 10
    topic quite sara but no one commented
    you're wrong buddy
    I just mentioned Zafir B 2006 today
    and after the exchange you won't fire her
    I'm just spitting about the environment
  • #6 17160904
  • #7 17161202
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Bieda z nędzą wrote:
    UEC exchange when you want for what you want
    After replacement, it is necessary to log in UEC, which consists in deleting the previous VIN and entering your own and configuring your car equipment.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • UEC module does not require VIN coding
    #8 17162774
  • #9 19295221
    mrucze
    Help: 34
    Rate: 85
    I will meddle with the topic after a few years, but both are right. UEC does not have a pin code, but only in cars with a rear REC module. Cars without a REC in the trunk have a pin code in the UEC. 100% sure and tested.
  • #10 19371427
    kamext
    I do not know what it depends on, but in Asterka I have a PIN request in both UEC and REC.
    You will replace the element and the car does not burn.
The discussion revolves around the UEC (Universal Electronic Control) module in the Opel Zafira B, specifically regarding the process of mentioning, coding, and appending the module. Users emphasize the necessity of entering the Vehicle Identification Number (VIN) and configuring the module to match the vehicle's equipment after replacement. Some responses clarify that while the UEC does not require a pin code in certain configurations, it may do so in others, particularly when a rear REC (Rear Electronic Control) module is present. Additionally, users note the importance of ensuring that all necessary fuses are in place and that features like daytime running lights may need activation post-installation. Overall, the consensus is that while some coding is required, the process is generally straightforward if the correct components are used.
