iPhone 6 Charger Detected but Not Charging: Empty Battery Screen, Port Cleaned, Tested Cables
Myfon 51390 4
  • Suspect battery replacement after charger detection fails
    #1 16548245
    Myfon
    Rate: 11
    The phone went unloaded, I plugged it under the charger in the evening, and only the empty battery appears on the screen all night long. The phone detects the charger, because after disconnection in addition there is a graphic with a cable suggesting connection to the charger. I cleaned the port of all the paprochów but the situation has not changed. I tried to do a so-called hard reset but nothing happens either. I searched the internet for a solution to this problem but everything I found did not work.
    I tried to load from different sockets, from a computer, using different cables and chargers, but nothing helps.
    Do I have to go with him to the service or maybe just replace the battery and if the problem does not disappear then continue to combine?
  • #2 16548289
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    barteksmrek wrote:
    Iphons do not have interchangeable batri.
    Do not write stupid as you do not know.
    To the author:
    How do you go to a good site where they check if the battery is for exchange. Generally, the reasons can be many and far away from you.
  • Battery replacement suggested for non-starting iPhone 6
    #3 16548293
    Myfon
    Rate: 11
    barteksmrek wrote:
    Myfon wrote:
    or it can only replace the battery
    Of course, they only need a phone to crank up. On the Allegro there are plenty of batteries to buy together with the sets of tools you need.
    barteksmrek wrote:
    Plug in and leave it overnight. disconnect and start the phone.
    I do not think it will help, because normally after connecting the charger the phone should start, and it only displays this animation charging on the entire screen.
    Now I will try to leave him for a long time under the charger, although he was lying all night today and nothing has changed.
    I will probably buy a battery and replace it, because it will cost me less than 50 zlotys and I will check if it helped, because the service will count me a few hundred :|
    Added after 1 [hour] 52 [minutes]:
    I would like to add that the screen looks like this when I try to start the phone:
    And after connecting the charger looks the same just disappears the cable and lightning, and the battery does not go up and the phone does not start. The charger and cable are fully functional.
  • #4 16549523
    spicter
    Help: 73
    Rate: 65
    Replace the battery.
    If there is no repair effect, you may have a damaged charger - responsible for controlling the charging of the IC U2 1610A2.
  • #5 16550349
    Myfon
    Rate: 11
    The problem solved itself. I randomly clicked on the phone's start button and I did not even look at it and suddenly turned on. It indicated 10% of the battery, and when connected to the charger, it immediately jumped to 77%. He sat the night on the charger and works today as before.
