Charging Interruptions and Power On Issues with iPhone 6: Is it a Damaged Charger?
asiaaa123 5181 7
  • #1 16302975
    asiaaa123
    Hello, I have a problem.
    I am the owner of the iPhone6.
    Always everything with the phone was fine.
    Recently I noticed that the charger terribly interrupts but I charge at a certain angle.
    Currently, the phone has discharged, it was connected to the above-described charger, but I do not want to turn on.
    After connecting the charger to the right angle, the phone shows the red battery. (attachment)
    Unfortunately, no attempts to turn on the phone (hard reset) did not bring results. What could be the reason for this situation? Is it possible that the phone will not turn on by a damaged charger? :(
    • Charging Interruptions and Power On Issues with iPhone 6: Is it a Damaged Charger? iphone6-ios8-phone-charging.jpg (42.54 KB) You must be logged in to download this attachment.
  • #2 16303008
    leonov
    Help: 1039
    Rate: 2248
    Rather, by a discharged battery ;-)
  • #3 16303014
    asiaaa123
    It's been charging for 1.5 hours now. The result is still the same ;)
  • #4 16303057
    leonov
    Help: 1039
    Rate: 2248
    And the charger is 100% efficient?
  • #5 16303103
    Jacol2084
    Rate: 21
    Rather at 100% by the charger, the charger is original?
  • #6 16303119
    Adam-T
    Help: 834
    Rate: 1096
    The original charger should be dismantled and the soldering on the usb socket improved. I see that this is a common accident of these chargers.
  • Repairing a disconnected cable inside the original charger
    #7 16305618
    asiaaa123
    No, it's not working. I'm only charging at a certain angle. I am also worried that when I connect the phone to the charger (I connected the phone to the original charger, which was completely broken but somehow I was able to turn on and recharge the phone up to 90%) I do not charge despite the fact that there is a stamp next to the battery. I am worried and I hope this is not a battery issue .....
    No, it's not original and sometimes I get the error that "the accessory is not supported"
    try :) Thanks :) It is through the usb socket that I have to strain myself to make the original work :)
    Added after 5 [minutes]:
    I undressed the charger. One cable is disconnected. How can I fix it? I have soldering guns 8-) But I would need some instructions, tips on how to do it :roll:
  • #8 16305718
    Adam-T
    Help: 834
    Rate: 1096
    A clear photo please.
The discussion revolves around charging interruptions and power-on issues with an iPhone 6. The user reports that their phone only charges at a specific angle and fails to turn on despite being connected to a charger. Responses suggest that the problem may stem from a discharged battery or a faulty charger. Several participants inquire about the charger's efficiency and whether it is an original Apple charger. One response indicates that common issues with these chargers include poor soldering on the USB socket, which can be repaired. The user later reveals that their charger is not original and has experienced compatibility errors. They also mention a disconnected cable within the charger and seek advice on how to repair it using soldering tools.
