Honda Civic 2007 Type S 2.2 Diesel - Speedometer, Power Steering Light and Check System Issues
Tobi1980 8295 2
  • Suspect gearbox speed sensor wiring or cluster fault
    #1 16548902
    Tobi1980
    Hello, I'm completely new, I have a problem with my honda civic 2007 type s 2.2 diesel. Namely, a few months ago I changed the clutch at the workshop, when I picked up the car, I had a problem with the fifth gear while driving, after a few months I checked the gearbox and it turned out that there is no oil in it completely, so I changed the gasket and poured the oil, then turned on the engine and the computer showed me two power-stering lights and a check system (the speedometer stopped working all the time shows 0 and I disconnected the power steering), so I replaced the speed sensor that is at the box and the support is noticeably back, but the light is on, while the speedometer still shows only 0, I will add that after replacing the sensor on the box I reset the computer but the error is still displayed on the console other clocks are working. I am begging you for help because I cannot afford to put my car in the garage.
  • #2 16549073
    mrx2000
    Help: 21
    Rate: 47
    I do not know what the patent is in your Honda, because in some cars you can buy a pulser separately, and a pulser drive separately, and I suspect that you might not have replaced the latter, and that is where the reason may be, the more so because there was no oil.
  • #3 16549088
    automobilklub
    Help: 21
    Rate: 176
    I do not understand what seal you are talking about, there is none between the gearbox and the engine ...
    What error is displayed? What are you using for diagnostics? Honda HDS?
    Check fuses: No. 10 (7.5A) under the dash and No. 16 under the hood.
    If OK, run gauge diagnostics:
    1. Turn off the ignition.
    2. Remove the instrument cluster module (speedometer).
    3. Disconnect the 12-way connector from the instrument cluster module (speedometer).
    4. Perform the tests according to the table: Honda Civic 2007 Type S 2.2 Diesel - Speedometer, Power Steering Light and Check System Issues
