Audi A4 B5 1.9 TDI 110km (AFN): Seeking Guidance on Vacuum Hose Replacement Process
deekline 13905 2
  • #1 16549206
    deekline
    Hello, I'm new to this forum, so I prefer to post a topic because I can't find my problem on the internet. Well, today I decided to replace the vacuum hoses, I started to replace the hose next to the servo (it is in the middle, between the water lines entering the vehicle body it goes from point A to point B Audi A4 B5 1.9 TDI 110km (AFN): Seeking Guidance on Vacuum Hose Replacement Process Audi A4 B5 1.9 TDI 110km (AFN): Seeking Guidance on Vacuum Hose Replacement Process ) unfortunately I cut it and started to pull it because I thought that there was a connection between the wires and there would be no problem with the replacement ... ) MY QUESTION: Where does this snake go and has anyone mentioned it?
  • #2 16549357
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Probably a pre-lift.
    This is the negative pressure for controlling the internal circulation damper.
    Search behind the cabin storage.
  • #3 16549571
    deekline
    yes, this audi is a pre-lift (1996). Well, sculpture is waiting for me today.
