KEMO vs Viano Marten Repeller: Comparing Effectiveness for Car Wire Protection
zbigniew9 15666 9
Czy odstraszacz kun do samochodu działa i który będzie skuteczniejszy: KEMO czy Viano?
Z tej relacji wynika, że Viano nie zadziałał, a skuteczniejszy okazał się KEMO, konkretnie model M071N z kontrolą dźwięku i głośnikiem [#17121100] Użytkownik napisał, że po Viano kuny atakowały auto mimo obecności urządzenia, natomiast KEMO M071N działał bezawaryjnie przez kilka lat i od tego czasu nie było dalszych szkód [#17121100] Wcześniejszy, tańszy KEMO M100N przestał działać po 2 latach [#17121100]
  • #1 16549481
    zbigniew9
    Rate: 20
    I warmly welcome
    In my car, once again, after replacing the mask soundproofing holes are visible
    and bitten electric wires. I'm thinking of buying a marten repeller. According to colleagues, does this device work?
    I found the KEMO producer, Viano. Which is more effective.
  • #2 16549514
    robokop
    Help: 1763
    Rate: 6365
    Buy a toilet cube - the one in the plastic basket, hung on the edge of the shell. Hang it on the cables under the hood and you will have peace. The method even tried out on the tank.
  • #3 16549534
    Megawe
    Help: 246
    Rate: 1433
    Not only martens enter the cars.
    Cars parked next to the trash are attacking rats, in the new Toyota RAV they have sprinkled the washers.
    Weasels make themselves a food storage.
    We did a test of the German device for repelling martens on a cat and dog, the cat did not react and the dog jumped for half a meter.
  • #4 16549536
    andrzej20001
    Help: 1578
    Rate: 6660
    Either way, the toilet pendant works
  • #5 16549545
    misiek1111
    Level 37  
    Help: 324
    Rate: 1088
    It doesn't work all alone. You need to soak it regularly with water.
  • #6 16551032
    robokop
    Help: 1763
    Rate: 6365
    Yes, and it must be Perrier Perlage. You didn't come up with the idea that the night and morning air has so much moisture that the cube will never dry to dust? The more that it smells dry.
  • #7 17121100
    zombek301
    Rate: 63
    Viano gave me nothing. Martens successfully attacked twice despite his presence. The cheapest Kemo M100N model stopped working after 2 years of purchase. Then I bought KEMO M071N. With sound control and speaker set. This proved to be good. It has been working flawlessly for several years and the martens have done no more damage. KEMO vs Viano Marten Repeller: Comparing Effectiveness for Car Wire Protection
  • #8 17121369
    coperfild
    Help: 291
    Rate: 1696
    Maybe the martens have moved out, it depends what animal bites someone :D
    There are also rats, squirrels, mice, cats, chinchillas, beavers etc ...
    You can put on a barbed wire with electricity, but when Chuck Norris comes, it won't help.
  • #9 17138916
    zbigniew9
    Rate: 20
    Good, we can have a little laugh. I put a Domestos cube in the engine compartment.
    I don't know if it works, I didn't stay there. ;-) .
  • #10 17138957
    MikeC
    Level 32  
    Help: 201
    Rate: 971
    There is nothing like opening a mask and seeing five cubes :) (astra j in the first review), some still hang stockings with the dog's fur (probably the dog's) apparently also works ...
✨ The discussion centers around the effectiveness of marten repellers, specifically comparing KEMO and Viano brands, in preventing damage to car wiring. Users share mixed experiences, with one noting that the Viano repeller failed to deter martens, while the KEMO M071N model proved effective over several years. Alternative methods, such as using toilet cubes and other deterrents, are also mentioned, but their efficacy varies. Overall, the KEMO M071N is highlighted as a reliable option for protecting car wiring from marten attacks.
