Which wire locator should I choose? Laserliner Plus 080.965A cable detector
Conrad.pl 15204 5
  • Laserliner MultiFinder Plus uses three detection methods
    #1 16320010
    Conrad.pl
    Rate: 10
    Modern locators work in two ways. Some of them use it induction effect , caused by electromagnetic fields. This method is easiest to detect electric wires through which alternating current, i.e. network cables, flows . The locator finds an electromagnetic field around the wire that is generated by the current flowing. Such a cable is very easy to locate in the wall, even at a depth of a few centimeters.
    The situation may be somewhat difficult if you need to locate metal objects through which no alternating current, i.e. dry conductors, reinforcement, etc., flows. For the detection of this type of elements, the fact that metals, especially steel, affect magnetic fields in their environment . Then the locator generates an electromagnetic alternating field. If the locator's sensor approaches the metal hidden in the wall, its vibration frequency changes. Then the measurement signal is analyzed and the result is indicated on the device.
    The inductive method can not, however, detect any objects that are not metallic. For example, in a dry-mounted wall where there are wooden supports for a supporting structure, for example to hang a cabinet, another technique is required. He is used for this purpose capacitive technology . locator then sends a variable field with a very high frequency. The material in the sensor detection area absorbs part of the energy and thus weakens the electric field. This is recorded by locator as a measurement signal and converted accordingly, in such a way that the display shows the position of the center and the edge of the hidden element.
    A powerful detector of wires with several integrated sensors is Laserliner MultiFinder Plus 080.965A
    - The device is equipped with an LCD display with user interface. Thanks to this, MultiFinder can be operated easily and safely
    - Acoustic and optical signals to search for items further facilitate service and guarantee high reliability in the location
    - Easy to use: after automatic calibration, the instrument is ready for operation immediately
    Laserliner MultiFinder Plus 080 detector.965A can detect live wires (up to 40 mm depth), locate non-ferrous metals (up to a depth of 50 mm, wood (up to 20 mm deep) and detect non-ferrous metals (up to a depth of 100 mm).
    Find out more >>
    Consent to the publication of // gulson
  • #2 16337481
    Brivido
    Help: 226
    Rate: 430
    Is he really so good and he detects wires under and without voltage?
  • #3 16339611
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    How privately and in the company I use MS6818 MASTECH and I will never exchange it for anything else. And its price is about 600 PLN.
  • #4 16358117
    Conrad.pl
    Rate: 10
    brivido,
    Laserliner MultiFinder Plus 080.965A is a scanning device for detecting metals, recognizing wall and crossbars in drywall and for locating live cables.
  • #5 16358273
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    In the robot we have a few different from some no name for BOSCH etc., and either it does not work as everyone imagines, or none of us just can not use it.
    I am rather for the second option, but for example, such a GMS100M after calibrating, it can show three different locations or distances with three (same) measurements, so something in the first option probably is.
  • Comparing Bosch D-tect 120 for locating pipes and cables
    #6 16372139
    jag3210
    Rate: 8
    Welcome,
    I need to buy a detector primarily for plumbing and plastic CO - exactly for drawing installations in the apartment for processing. I found Bosch D-tect 120 for PLN 900 but is it a good device for this? Will it show me what it needs (is it a pipe or cable) or just show that something like that is there?
    I have max 1000 PLN for this investment. Can you recommend something?
    Regards and thank you.
    Jarek
