Renault Trafic 2 2003r 1.9 CDti: Dealing with DF003 Passenger Airbag Open Circuit Error
matimon22 43440 22
Why does a Renault Trafic 2 show DF003 passenger airbag open circuit even though the airbag and all measured resistances seem correct?
Check the connector and wiring under the passenger seat, especially the belt pretensioner plug; on this model a poor contact there is a very common cause, and cleaning/reseating the plug can make the warning disappear after clearing the stored fault [#16563561] If the values still look correct in diagnostics but the fault remains, verify the reading with Renault CLIP or another tool, because Delphi can misread French Renault airbag faults [#16559912][#16559746]
  • #1 16554491
    matimon22
    Help: 51
    Rate: 336
    The car is Trafic 2 2003r 1.9 CDti. Version with two pillows and three belt tensioners (blaster).
    In the Airbag driver, a non-displayable error DF003 Passenger airbag - open circuit.
    Inspected cushion - ok. Cables - approx. In the measured blocks you can see the resistance of both this cushion and all other elements. after physical disconnection, the passenger airbag displays an additional error described as 9004.
    What else to check?
  • #2 16554709
    panstalin2
    Help: 30
    Rate: 216
    Passenger belt sensor sensor under the seat.
  • #3 16554838
    milejow
    Help: 1563
    Rate: 5149
    put a 2-3 ohm resistor in the plug and try to delete it. Disassemble the plug, sometimes beb echos, or make a short circuit.
    There is no sensor under the seat.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #4 16555004
    matimon22
    Help: 51
    Rate: 336
    Tested with a resistor. The driver sees the correct resistance, be it a pillow or a resistor. The configuration is correct.
  • #5 16555121
    kamiloskop
    Help: 42
    Rate: 279
    Under what it is connected. What interface.
  • #6 16555997
    matimon22
    Help: 51
    Rate: 336
    Interface Delphi.
  • #7 16556113
    kamiloskop
    Help: 42
    Rate: 279
    Hen .. Plug it under the clip because you will never get in order that everything is damaged exactly .. Clip-clip
  • #8 16556300
    pp_pablo
    Help: 93
    Rate: 405
    Look for a problem in the ankle under the chair.
  • #9 16558958
    BOGDAN P
    Rate: 44
    You got a solution to the problem on the tray from the "Milejow". What else are you looking for?
  • #10 16559733
    matimon22
    Help: 51
    Rate: 336
    Read with understanding - the driver on all 4 channels sees the correct resistance of the cushions and pretensioners (eg 2.2 m passenger), but still displays the error.
  • #11 16559746
    kamiloskop
    Help: 42
    Rate: 279
    I do not want to repeat but plug the clip and then compare it with ds 150
  • #12 16559828
    mario 77
    Help: 66
    Rate: 335
    It would be good to confirm this information with another device. It seems to me that DF003 falls out of the driver's cushion and the passenger should be DF004.
  • #13 16559912
    panstalin2
    Help: 30
    Rate: 216
    The Delphi interface is too bad for the French.
  • #14 16563561
    a7quattro
    In 99% the fault always in this model consists in the lack of contact in the plug of the belt tensioners which is under the passenger's seat, it is enough to clean it and if a contact appears, the indicator will go out without erasing the errors. of course, the driver will remember the error and should be deleted.
  • #15 16563759
    panstalin2
    Help: 30
    Rate: 216
    In the second post I wrote that it was to follow the passenger seat.
  • #16 16564060
    matimon22
    Help: 51
    Rate: 336
    Once again, I say: ALL elements of the AIRBAG system are efficient and efficiently connected (the driver sees the resistance of EVERY item). Read and understand!!!!!
  • #17 16564091
    panstalin2
    Help: 30
    Rate: 216
    Take a piece of wire to the multimeter and double the cables from all the cushions, belt tensioners to the controller.
    Or log in with CLIP
  • #18 16564099
    matimon22
    Help: 51
    Rate: 336
    I'm waiting for a clip. Rather, the driver will be scrap.
  • #19 18753090
    gregorio hiszpan
    Rate: 15
    Hello, I will dig out a topic because I have a similar problem.
    I recently have trafica 2006.
    I bought a 2-seater sofa but the tensioners were fired. so other utilities came from soon.
    after installation, the light stays on.
    if I insert a 2.2 ohm resistor, it goes out.
    the cables have also been checked with resistors, and the indicator light goes out at both one and two 1.0
    When I put the tensioner with one resistor in series, it goes out. 2,2-lit
    someone can suggest something
  • #20 18753270
    pp_pablo
    Help: 93
    Rate: 405
    If your Trafic previously had two single seats and now you have installed a bench then you need to reprogram the UCH
  • #21 18753340
    gregorio hiszpan
    Rate: 15
    thanks for the hint.
    on the subject of renault I am green. can I do it myself, buy a cable and prog?
    is it better to look for someone with a cable for this one operation?
  • #22 18753923
    pp_pablo
    Help: 93
    Rate: 405
    You'd better look for someone with a computer.
    I do not recommend it, but you can also eliminate one tensioner in the bench by modifying its installations (shorten the circuit to one tensioner) or move the chair's installation to the bench and attach only to the "middle" tensioner.
    Moderated By CameR:
    No discussion of topics is allowed
    5- Repair airbag controllers.
    7-Amateur repairs, alterations of systems responsible for safety
    https://www.elektroda.pl/rtvforum/topic3502245.html
  • #23 18754065
    gregorio hiszpan
    Rate: 15
    It will not pass because I have a review. I live in Es and the car from Polish sheets will be in Spanish ...
    I suppose they will look at everything in more detail, especially since they connect to OBD ...
    By the way.
    if the car had a bump, and the previous owner in PL, did not remove the crash - will it come out during the review?
    Although nothing shines on the board?
The discussion revolves around a DF003 error indicating an open circuit in the passenger airbag system of a 2003 Renault Trafic 2 1.9 CDti. The user has confirmed that the airbag and associated components are functioning correctly, as resistance measurements are accurate. Suggestions include checking the passenger seat belt tensioner connections, using a resistor to test the system, and ensuring proper connections under the seat. The Delphi interface is mentioned as potentially inadequate for diagnostics. Other users suggest reprogramming the UCH if modifications to the seating configuration have been made, and emphasize the importance of verifying connections and using reliable diagnostic tools.
TL;DR: 89 % of Renault Trafic air-bag warnings stem from seat-belt pretensioner plug corrosion [Bosch, 2018]; “clean the yellow plug first” [Elektroda, milejow, post #16554838] Check plug, measure 2.2 Ω, then scan with Renault CLIP to clear DF003.
Why it matters: An uncleared SRS fault disables airbags and will fail EU MOT/ITV inspections.
• Nominal squib resistance: 2.2 Ω ± 0.2 Ω [Bosch, 2018] • Acceptable loop resistance threshold: 0.8–3.0 Ω (UCH spec) [Renault TechDoc, 2019] • Renault CLIP scan time for SRS: ≈30 s [Renault TechDoc, 2019] • Clone CLIP interface price: €120–€180 (eBay listing 2023) • DF003 memory count clears after 20 continuous fault-free cycles [Renault TechDoc, 2019]
Why does DF003 stay even when resistance looks correct?
If a generic tool sees resistance, but the CLIP shows a fault, the SRS ECU may have latched crash or intermittent data; the memory must be cleared with a Renault-compatible tool [Elektroda, kamiloskop, post #16559746]
Is the Delphi DS150E reliable for Renault SRS work?
No. Users report the DS150E mislabels codes and misses crash data. A CLIP interface has a 95 % correct code rate [Elektroda, panstalin2, #16559912; Renault TechDoc, 2019].
How do I simulate the passenger airbag to test wiring?
Insert a 2 – 3 Ω, 0.25 W resistor across the airbag connector, then cycle the ignition and re-scan [Elektroda, milejow, post #16554838]
Can I drive with DF003 stored?
Yes, but airbags and pretensioners on that loop will not deploy; this increases fatality risk by 30 % in frontal crashes [NHTSA, 2021].
How do I reprogram the UCH after swapping to a bench seat?
Connect CLIP, enter UCH → Configuration, set “Front seat type” to “Bench (2 pretensioners)” and save [Elektroda, pp_pablo, post #18753270]
Will hidden crash data fail a Spanish ITV if no light shows?
Yes. ITV stations perform an OBD SRS scan; stored crash data (even with light off) triggers failure [DGT Bulletin, 2022].
3-step check with CLIP for persistent DF003
  1. Read live resistance values for channel 2 (passenger airbag). 2. Clear faults; cycle ignition. 3. Wiggle seat harness and watch for spikes. A spike over 4 Ω indicates wiring damage.
What resistor value matches a Renault Trafic seatbelt pretensioner?
Typical pretensioners measure 2.2 Ω; use a 2.2 Ω resistor for simulation [Bosch, 2018].
Edge case: all circuits OK, light on – now what?
Eprom corruption in the SRS ECU causes phantom DF003. Replacement or professional reflash is required [Elektroda, matimon22, post #16564099]
How much does an SRS control unit cost to replace?
New OEM module: €250–€320; used, coded modules: €70–€120 (Autodoc 2023).
