[Solved] Renault Trafic III 1.6 120km - Adblue Exhaust System Issue: Fuse, Heating & Module Queries
kuleszapawel 71703 2
  • Suspects AdBlue module after fuse replacement
    #1 19250668
    kuleszapawel
    Rate: 28
    On the clocks "check the exhaust system".
    When connected to Clip, the following errors:
    Photo of a laptop screen displaying car diagnostic results with errors related to the AdBlue module.
    I tracked down the faulty fuse in the box under the engine compartment:
    Fuse box with a highlighted faulty fuse.
    After the replacement, the Adblue heating errors went out, but there was one that could not be removed:
    Laptop screen displaying diagnostic of AdBlue module error.
    The error after clearing appears immediately after the second or third start of the engine.
    I will add that I tested all adblue elements, you can hear them working.
    Bet on the module?
    Does the module need to be programmed for a given car?
    • Renault Trafic III 1.6 120km - Adblue Exhaust System Issue: Fuse, Heating & Module Queries 20210211_154802_resized_1.jpg (195.1 KB) You must be logged in to download this attachment.
    • Renault Trafic III 1.6 120km - Adblue Exhaust System Issue: Fuse, Heating & Module Queries 20210211_151800_resized_1.jpg (193.24 KB) You must be logged in to download this attachment.
    • Renault Trafic III 1.6 120km - Adblue Exhaust System Issue: Fuse, Heating & Module Queries 20210211_112745_resized_1.jpg (216.87 KB) You must be logged in to download this attachment.
  • #2 19251563
    kuleszapawel
    Rate: 28
    After connecting the LAUNCH device, the error looks like this:
  • #3 19336211
    kuleszapawel
    Rate: 28
    Problem with the upper NOx probe, after replacing the problem disappeared.
