MAN TGA 480 codes - ERROR CODES 04156-04, 04562-04 MAN TGA 480 2008.
aska0310 17583 3
  • #1 16561519
    aska0310
    Hello, who knows what these errors mean EBS: 04156-04,04562-040, 04169-00 I will add that, what's the worst, it disconnects the brakes at this time, when it clears the error, they light up again in the hole. I would like to add that discs, pads, etc. were changed not long ago. in the trailer. BEST REGARDS
    darfur5
    Help: 267
    Rate: 1715
    Added after 7 [minutes]:
    Hello. EBS 4156-04: CAN brake signal at wheel 2, no signal. Check the plugs in the modulator on this wheel, wiring. 4562-04: CAN brake signal at wheel 1, message 12 timeout. Treat this like the previous error. You can also delete the errors and make a test drive, if errors appear, unfortunately you have to look for the cables.
  • #3 16561628
    aska0310
    So there should be nothing costly? And this 3 code 04169-00?
  • #4 16564893
    darfur5
    Help: 267
    Rate: 1715
    CAN signal on wheel 2, message 11 timeout. Procedure similar to previous errors; check the wiring from the modulator on this wheel to the controller, disconnect the UB, CAN-H and CAN-L plugs, check if they are in good condition. It may happen that the modulator is dead or the EBS driver, but before you get down to it, check what I described earlier.
