Interpreting MAN TGA Error Codes: EBS 04546-00, ZBR 00597-08, EBS 01067-05
fubi2011 52266 5
  • #1 15384759
    fubi2011
    Rate: 8
    Hello everyone.
    At the same time, I received such error codes EBS 04546-00 ZBR 00597-08 EBS 01067-05. What does it mean and where to look for it. Regards Leszek
  • #2 15386030
    darfur5
    Help: 267
    Rate: 1715
    Hello! I will only try to help you without laughing because this is a translation from English.
    EBS 0456-00 request for a red warning light.
    EBS 01067-05 brake signal module 1 short circuit to ground
    ZBR 00597-08 brake sensor - distorted signal.
  • #3 15389412
    kakibara
    Help: 202
    Rate: 1284
    Hello, I would personally deal with the brake pedal position sensor, first check that the ankle is not detached, after changing to another error, it will disappear if you have one.
    After opening the mask, you will find the valve sticking out with 4 air ducts on the left side, and it is tightened from the inside - good luck.
    fuses and the ankle is not disconnected!
  • #4 15390041
    klika60
    Help: 20
    Rate: 278
    You probably have a foot brake pedal valve to replace
  • #5 15392870
    fubi2011
    Rate: 8
    Ok, I'll take care of it tomorrow. I will check the electric cube and the installation. is it from the outside of the car under the hood or from the inside of the cabin?
  • #6 15393095
    kakibara
    Help: 202
    Rate: 1284
    Hello, the installation is from the inside.
