[Solved] MAN TGA 18.440: EBS Fault Code 04601-00 - Seeking Help & Meaning of Error Message
kamil5093 29739 3
  • #1 16643984
    kamil5093
    Rate: 46
    please help tga man appeared koda ebs 04601-00 does anyone know what he means?
    dare23
    Level 19  
    Help: 32
    Rate: 242
    EBS 4601: Wheel brake lining wear sensor 3: Too much difference between 2 signals on this and the other side of the axle.
    Error status: FMI 0 - error not specified.
    Error indication: Central STOP warning lamp (H111) lights up yellow.
    Effect of Error: None of the user functions are restricted.
    Cause of error: Mechanical wheel brake error.
    Troubleshooting: Check the brake cylinders and brake linings on this axle.
    So you need to check the lining wear on the 2nd axis and find the reason for the differences in their thicknesses.
  • #3 16644096
    kamil5093
    Rate: 46
    Thank you for your help, best regards
  • #4 17045007
    kamil5093
    Rate: 46
