replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp
comandos21 6696 13
How can I make a screwdriver converted from Ni-Cd to a 5S Li-ion pack start at full speed when the trigger is pressed hard?
The most likely cause is that the BMS/balancer is limiting the startup current, so the screwdriver either needs to be connected directly to the pack or fitted with a BMS that can deliver much higher current [#16561719][#17430183] In the thread, bypassing the BMS output and connecting the screwdriver to B+ and B- made the tool work normally, while the BMS output on P+ and P- did not [#16561719][#17430183] If you wire the tool directly to B+ and B-, the BMS will no longer disconnect the pack on deep discharge, so you must watch the pack voltage yourself [#16561852] A small digital voltmeter or LiPo voltage buzzer was suggested for this purpose [#16561852][#16561921] The safe minimum mentioned for a 5S pack was 3V per cell, or 15V total [#16561919] Another user with a similar screwdriver reached the same conclusion: use a balancer/BMS with higher current capability, or one whose main output is effectively common with the cell pack so the full battery power is available [#17430183]
  • #1 16561601
    comandos21
    Rate: 105
    Hello, I already know one of my posts but I have a problem with the Verto screwdriver. I replaced a ni-cd battery cartridge (it no longer held voltage) for a li-ion battery with a 5S balancer.
    The battery charges to 21V, probably because it has so much input.
    But there is one "but" screwdriver after suddenly pressing the rotation button does not suddenly go into high speed only when I press the button gently but sensitively gives you to go into high speed and are awesome ... Tell me how to "give a kick" to the screwdriver's engine when suddenly pressed the button worked as it should
    I am asking for help and best regards.
  • #2 16561629
    goldi74
    Help: 1367
    Rate: 1539
    And what Li-Ion cells were used for the conversion?
  • #3 16561686
    comandos21
    Rate: 105
    1200mAh sanyo cells
    5 pcs in series.
    Kila pics.
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 20170630_211614.jpg (1.38 MB) You must be logged in to download this attachment.
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 20170630_210324.jpg (1 MB) You must be logged in to download this attachment.
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 20170630_211624.jpg (1.02 MB) You must be logged in to download this attachment.
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 20170630_212157.jpg (154.2 KB) You must be logged in to download this attachment.
  • #4 16561701
    Jawi_P
    Level 36  
    Help: 260
    Rate: 714
    This is a question whether new or recycled.
    If you stop the accelerated engine with your hand, does it get up and move on?
    If not, I suspect that during the sudden start there is a significant power consumption, there is such a large voltage drop that the controller stupid / hangs.
    I mean the current efficiency of the cells is too low.
  • #5 16561704
    comandos21
    Rate: 105
    The laptop battery is still operational.
    It cannot be stopped by hand at too high a speed as I give for drilling, and as I give the clutch on 3rd gear, the ram after releasing the head goes on.
    She has a problem with the engine kick.
    Some capacitor in front of the motor can give?
  • #6 16561719
    goldi74
    Help: 1367
    Rate: 1539
    It is also possible that the BMS (balancer) itself limits the current flowing during start-up. Make a test by directly connecting the Li-Ion pack to the screwdriver, bypassing the BMS system. Then you will know what the cause is.
  • #7 16561722
    comandos21
    Rate: 105
    I hooked up as you wrote the propeller nice.
    What to do now?
    How to do it
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 20170630_232521.jpg (1.04 MB) You must be logged in to download this attachment.
  • #8 16561739
    comandos21
    Rate: 105
    In the diagram, P + and P-are from the input and output voltages.
    Do P + and P- only on the charger plug or something?
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 2017-06-30-23-32-22.png (851.58 KB) You must be logged in to download this attachment.
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 20170630_232525.jpg (1.13 MB) You must be logged in to download this attachment.
    • replacing the ni-cd battery with a 18V li-ion screwdriver does not go at high sp 2017-06-28-10-47-07.png (682.14 KB) You must be logged in to download this attachment.
  • #9 16561852
    goldi74
    Help: 1367
    Rate: 1539
    You can do that. However, then BMS will not disconnect the packet from the load when the cells are discharged excessively. You will need to feel when the packet is unloaded or load it more often. Alternatively, add a small digital voltmeter for a few zlotys and check the package voltage with it.
  • #10 16561913
    comandos21
    Rate: 105
    Do you mean any specific voltmeter?
    I will make cancer because there is no point in buying another balsnser.
    How many volts max to discharge the battery?
  • #12 16561921
    wodzu12240
    Help: 5
    Rate: 27
    Hello, it can be used as in this link, If the voltage drops below the set limit, the buzzer will turn on. Just like in this movie. https://www.youtube.com/watch?v=bn9R3RiBctE. On the well-known portal, enter the LIPO voltage buzzer meter then you will find what you are looking for.
  • #13 16562227
    comandos21
    Rate: 105
    That's what I ordered, also connecting each cell to the balancer so that the meter monitors the voltage individually?
  • #14 17430183
    morling1
    Rate: 49
    I have a similar problem.
    I used the same balancer as the one shown here on the forum and the Ryobi CDI-1801 18V screwdriver does not count, unless the starting current is too high. While the EUROTEC WPCD105 18V screwdriver does not go hand to stop working so well. Tested on SAMSUNG INR 18650-15Q 1500mAh cells with 18A short-circuit current.
    I was tempted to do the same test only on SONY US18650VTC4 2100mAh cells with 30A short-circuit current, the situation is similar to that with EUROTEC engine until the smoke goes.
    Conclusion: if what is mentioned above in the previous posts is true that without a balancer some screwdriver started (I did not test) and with the balancer not, then I wonder why since the balancer gives - it allows such a high current at the start that until the EROTEC went smoke from the engine and the screwdrivers are not going to be stopped by hand - a grip on the rotating bit clamp, are there other screwdrivers that in their normal work need even greater?
    For the above, I conducted a test because it gave me no peace. I desoldered the wires from P + and P- to bypass the output of the whole voltage of the packet from the balancer and soldered to B + and B- to connect the current output directly to the battery packet without the balancer and the screwdriver started. At the same time, I find that the Ryobi CDI-1801 18V screwdriver on the cell pack works a little less than EUROTEC WPCD105 18V and you can safely stop it by hand, which would suggest a less-rigid Ryobi transmission or a weaker engine, but more power-consuming. The solution to the above, for the screwdriver to work with a balancer controlling cell discharge, would be to look for a balancer giving higher current output or one in which + the whole battery, all cells connected in series is simultaneously + blender, similar to the minus is also common. Then the full battery power will be released.
    Something like the link below except it's 4s, not 5s:
    https://www.google.pl/search?q=balanser+5s&so...UICigB&biw=1024&bih=613#imgrc=dydWHcFIJnnHCM:
    I also found 5s a little bit stronger than the one from previous forum posts:
    https://www.google.pl/search?biw=1024&bih=613...+40a&gs_l=img.3...25046.25858.0.26212.4.4.0.0. 0.0.71.240.4.4.0 .... 0 ... ... 1c.1.64.img..0.1.71 0i30k1.0.cuTu5ac4kvs # imgrc = __ BDySJDf9jgoM:
The discussion revolves around a user who replaced a Ni-Cd battery in a Verto screwdriver with a 5S Li-Ion battery pack, which charges to 21V. The user experiences issues with the screwdriver not reaching high speed unless the button is pressed gently, suggesting a problem with the motor's initial power draw. Responses indicate that the issue may stem from the battery management system (BMS) limiting current during startup or the current efficiency of the Li-Ion cells being inadequate. Suggestions include bypassing the BMS to test performance and monitoring battery voltage to prevent over-discharge. Other users share similar experiences with different brands, indicating that high starting current requirements may be a common issue across various models.
