Installing a camera on the window of your apartment on the parking lot
radex324 22440 13
Can I install a camera from my apartment window aimed at the parking lot, and do I need permission or special approval?
Yes, the thread consensus is that you can install such a camera, especially if it only watches the parking lot or your own parking space [#16563102] If any private apartment windows are in the field of view, set privacy zones/masks so those areas are not recorded [#16562902] One reply adds that if you want to screw the camera to the wall, you should have permission from the building administration, while attaching it to the window glass was treated as less problematic [#16562943] For a camera aimed only at your car or the parking area, the cooperative or a neighbor is not considered the authority that can simply forbid it; if they object, they can complain to the data protection authority [#19001575] A sign indicating that the area is monitored was also suggested for security [#19001575]
  • #1 16562851
    radex324
    Help: 50
    Rate: 206
    Hello there, I read the topic Electrode and I wonder if something has changed in this topic, is it allowed to install an outdoor camera aimed at the parking lot (or 1 parking space) in the block (a few bought apartments)
    Best regards.
    Added after 7 [minutes]:
    There are plenty of topics and no answers are possible or not :)
  • #2 16562902
    michualex
    Help: 82
    Rate: 134
    Best regards.
    If there were any windows of private properties within the camera view, privacy zones should be separated there and everything is fine.
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #3 16562910
    radex324
    Help: 50
    Rate: 206
    And if the camera is aimed only at the parking lot, do you need a permit, etc.? Because until I do not share it, nobody can do anything because it does not violate the rights of personal data as far as I know.
  • #4 16562915
    michualex
    Help: 82
    Rate: 134
    Well, you've exhausted the topic :)
    For logic, everyone on the road equipped with recorders would also have to have permits :)
    MK ALARMY
  • #5 16562926
    radex324
    Help: 50
    Rate: 206
    And the administration of the block can order you to download something? Because here, in every topic, the answer is different hehe
  • #6 16562943
    michualex
    Help: 82
    Rate: 134
    Well, if you want to screw it to the wall, you'd better have permission.
    But if you stick to the glass, I think they can kiss you :)
    Same topic as with sat antennas.
    MK ALARMY
  • #7 16562953
    radex324
    Help: 50
    Rate: 206
    For the window sill it is the same as for the window, i.e. I assume what cameras are of good quality.
  • #8 16562964
    kokapetyl
    Help: 1787
    Rate: 2101
    Not a problem (assembly)
    The fundamental question is.
    Is it allowed to monitor any area without such information, without permission?
    There are monitoring in public places, but information about it is visible.
    In your case, I am not entirely convinced. Maybe someone has a different opinion?
  • #9 16562970
    radex324
    Help: 50
    Rate: 206
    I'm just waiting for the opinions of other users, maybe someone has already installed it like that, I don't want them to steal twice.
    I will add that the cameras are mounted in the middle of the block.
  • #11 19001489
    anett250
    I am writing to you in relation to the topic. Some time ago I installed a camera on the window frame. There was only one reason, damage to movable property by an "unknown" perpetrator. It was a pity at 9,000. Currently, I have another car and I am afraid of a repeat of the situation because the neighbor is conflicted and since she saw that I have a new car, she reported to the cooperative that I infringe her privacy, although the camera has been hanging for a year. The cooperative is on her side and she tells me to dismantle the camera whose image is directed only at my car. I know that he wants to damage my car again and I'm afraid for my property. Help, what should I do?
  • #12 19001506
    kazikszach
    Help: 513
    Rate: 1102
    anett250 wrote:
    The pity was at 9,000 thousand.
    Change because that's 9 million.
  • #13 19001575
    cysiekw
    Help: 1003
    Rate: 1410
    nothing, the community or "somsiad" are not the authority that can prohibit you from doing this, if they want to go to the knives, they will report you to the PDA and then notify you of the opening of an investigation. For security reasons, I would make a sign, for example behind the car window, that it is monitored.
  • #14 19002172
    anett250
    Thank you for your answer
The discussion revolves around the legality and practicality of installing a camera on an apartment window aimed at a parking lot. Users express concerns about privacy, permits, and potential conflicts with property management. Key points include the necessity of ensuring that the camera does not infringe on the privacy of neighboring properties, the ambiguity surrounding the need for permits, and the general consensus that monitoring a parking area is permissible if privacy zones are respected. One user shares a personal experience of facing opposition from a housing cooperative after installing a camera for security reasons, highlighting the tension between personal security and perceived privacy violations.
