TV BOX MXQ PRO 4k causing slow internet on all devices: WiFi, Ethernet, TP-Link W8961ND Router
Shakti 4545 2
  • #1 16742984
    Shakti
    I bought the TV BOX MXQ PRO 4k and the problem is that after starting the device, even without launching any application, it will silt the entire internet at home on all devices. To the extent that the speed test does not indicate any speed, ping jumps, and normally I have about 6 Mb / s. I don't see anything downloading, android is version 6. It doesn't matter if I connect it via WiFi or via Ethernet. Factory reset does not help, interestingly the internet is silted even when resetting the device. I am using neostrada and Tp-link W8961ND router.
  • #2 16743031
    BILGO
    Help: 393
    Rate: 724
    Set up some QoS in the router if it has one, so as to limit access to the Internet via BOX
  • #3 16743068
    Shakti
    But on the TV box it is also silted up and you just can't use it
